Motorcraft Platinum AGPS092P spark plugs are they anygood ?
Just bought another Cossie & removed the plugs to check & found its fitted with Motorcraft Platinum AGPS092P spark plugs, iv'e only really used Champion C59C's in my other Cossie's with no problems so never heard of these plugs. Will they suit my car, its running RS500 8 inj & about 400bhp, has run fine except under full load in 5th on acceleration it dropped onto 3 cylinder at 130mph (private test track) backed off & has'nt been a problem since but not been upto that speed since. They are gapped at 0.75mm,last owner had them fitted 1 month ago whilst car was being serviced at GGR.
Cheers Simon.
Cheers Simon.
I tried these but car felt flat as hell, replaced with another set of AGPR12PP8, well the DENSO equivalent as these are usually what is in the box, even from ford, but ace plugs, much crisper response, especially with group a coil.
OK thanks , just noticed that the plugs iv'e got fitted must be standard ones as the sticker on the i/cooler has the spark plug number on there which is the original sticker from factory. Its still running the original coil so may change that as i found it helped things on my last Cossie.
Cheers Si
Cheers Si
deathrider666
Sep 28, 2015 06:12 PM
