knock sensor access
Old May 23, 2007 | 02:49 AM
mxquattro's Avatar
mxquattro
Default knock sensor access
anyone know hot to get access to the knock sensor connector? I just cant fit my hands down the side of the block to find it, so Im hoping that the connector for it is somewhere easily accessible.
thanks!
Old May 23, 2007 | 09:29 AM
Rippers's Avatar
Rippers
Monte Geek
Its under the exhaust manifold near the back, I can get to it if you remove the turbo heat shield or from underneath if you take the o/s wheel off
Old May 23, 2007 | 10:52 AM
mxquattro's Avatar
mxquattro
Oh really? crap I was looking on the entirely wrong side of the motor. I thought it was behind the distributor under the injector rail. Thank you!!
Old May 23, 2007 | 10:57 AM
Rippers's Avatar
Rippers
Monte Geek
You can see it with the wire hanging out in this pic
Old May 23, 2007 | 03:02 PM
mxquattro's Avatar
mxquattro
PERFECT! Thank you a million
exactly what I was looking for
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
