help with immobilser
Old May 22, 2007 | 09:24 PM
base190380's Avatar
base190380
Default help with immobilser
hello, i have recently purchased a escort with a immoboliserr which is non standard ford i believe. the trouble is all the labels are worn off and i cant identify it, because i need to order a new chip key and cant, so was hoping somone may be able to shed some light on it.
It is a small chip with 8 pins on the board and is housed on a rectangular plastic case with a sloping bottom end for the keyring hole. It has half of a silver sticker on it with writing saying immoboliser, and has a pictue of what looks like a car in a target sight like a skope of a gun! Any ideas anyone. It plugs into a socket in the dash.
Old May 22, 2007 | 09:37 PM
rsvan's Avatar
rsvan
the company that made then went bust years ago mate
Old May 22, 2007 | 11:25 PM
SafeChav's Avatar
SafeChav
with all due respect that immobiliser is the biggest piece of shit ever made, you'd do extremely well to rip it out and fit a category 2 immobiliser, or even better a category 1 alarm
Old May 23, 2007 | 05:35 AM
As said biggest load of garbage going, bought a car a couple of years ago with one, when I picked the car up(astra mk3) I lost the bloody key at the service station in the snow somewhere, mate was with me so had a few tools, took all of 2 minutes to bypass as so simple.
Take it out would be my advice as well, and get a nice CAT 1 .
alarm/immoby .
ps if you pull the CARD part out of the holder you will see the connection details so can just copy them for a quick job.
Old May 23, 2007 | 06:21 PM
base190380's Avatar
base190380
seems im in the s**t then! do you know the name of the manufacturer anyway so i can do some research on it?
Old May 23, 2007 | 07:29 PM
rsvan's Avatar
rsvan
most fitters fitted them to one cut off witch caused the plastic key to heat up and melt, as for getting the name of it, might be worth getting the control box out from under the dash
Old May 23, 2007 | 10:28 PM
SafeChav's Avatar
SafeChav
as far as im aware they dont have a control box..........it just does some simple loops in the cars wiring, when you pull the key out they go open circuit
Old May 23, 2007 | 11:58 PM
rsvan's Avatar
rsvan
ye you could be right there, was long time ago.
best of luck sorting it
Old May 24, 2007 | 06:40 AM
As safechav says no control box at all, it's a FOUR circuit immobliser but wires and particularly the COPPER tracks inside the "KEY" are so thin it will not carry much current at all, so most had the circuit doubled up to act as a two circuit immobiliser, a two year old can get round this one, not even worth taking out the box IMO.
The immoby bit is the connection details on the card that you just pull out of it's holder to replicate.
Old May 27, 2007 | 04:43 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
not seen one of them in a while!!
H11SOW
Jun 24, 2014 04:08 PM
xr4x4rs
Apr 25, 2014 04:34 PM
ryan wilson
Jul 20, 2010 01:34 PM
airzfocus
Ford Focus RS
May 23, 2010 12:48 PM
morto
Aug 17, 2004 08:54 PM
