Engine won't stop running
Old Sep 20, 2004 | 11:00 AM
zvhturbo's Avatar
zvhturbo
Default Engine won't stop running
When i turn the ignition off the engine continues to run.
Could this be due to a dodgy ignition relay?
Am i drawing too much power through it or something?
Matt.
Old Sep 20, 2004 | 11:01 AM
RANJ's Avatar
RANJ
igntion timing maybe
Old Sep 20, 2004 | 11:02 AM
zvhturbo's Avatar
zvhturbo
Don't be stupid.
Its fully electronic management.
Old Sep 20, 2004 | 11:04 AM
Jon ERST S2's Avatar
Jon ERST S2
I had it for a while - but only when the lights were on. Stopped when I changed the loom over...
RANJ's Avatar
RANJ
didnt see you write ur spec of ur install wen u asked for help
Old Sep 20, 2004 | 11:08 AM
zvhturbo's Avatar
zvhturbo
It happens really randomly, some times it will some times it won't.
They only way to stop the engine is to disconnect the battery or pull 3 ignition leads off.
i have never tried it with the lights on though.
The reason i think it may be the ignition relay is because this controls all the other relays in my setup (the switch for all other relays is the power from the ignition relay)
The ignition relay has a permanent power from the battery and the switch is the ignition switch.
Old Sep 20, 2004 | 11:09 AM
zvhturbo's Avatar
zvhturbo
I only though over run due to ignition timing happened on Carbed engines with a mechanical fuel pump??
Old Sep 20, 2004 | 11:12 AM
MrsFrog's Avatar
MrsFrog
Hey... My golf does that too... weird.... Would like to know why ....
Switch her off and she keeps running... bless her...
Sorry can't help with yours tho... I am crap at mecanics!!!
Old Sep 20, 2004 | 11:16 AM
Ginge !'s Avatar
Ginge !
just finding my feet
my cossie does that too, think thge turbo timer might have somthing to do with it though
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
mattman1234
24
Aug 1, 2015 11:46 AM
