efi co pot question
Old May 20, 2007 | 04:16 PM
jonesymk2's Avatar
jonesymk2
Default efi co pot question
wud it make much difference if the co pot was disconnected while car was ticking over,also the plug has 3 wires on it i presume 1 is the earth but the other 2 wires both hav voltage running through them when the plug is disconnected,is this correct as i wud hav thought that only 1 wire should hav voltage running through it then when you connect the plug then voltage wud run through the other wire aswell
Old May 20, 2007 | 06:31 PM
jonesymk2's Avatar
jonesymk2
anybody
Old May 20, 2007 | 11:58 PM
SafeChav's Avatar
SafeChav
Yes it will make a difference being unplugged.
Its wired in series with the TPS so you may well get readings on a couple of the wires, its acting as a potential divider so needs a power supply across it.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
