3 door , wet carpet ? help
Old May 19, 2007 | 04:54 PM
rabmc's Avatar
rabmc
Default 3 door , wet carpet ? help
As above now this is a new one for me , its been chucking it down at a serious rate over the last few days and now my carpets wet its sat for 2 days and not moved and went i today to find this its wet basically at teh right side of accelarator and the plastic trim at the right if you feel up above this sort of going up behind dash on bottom right side its wet too in areas , now this is the only place , checked water level and is perfect so think this may rule out heater matrix wheres common for it to let water in in this area , where my speedo cable goes through bulkhead the rubber grommet has seen better days and to be honest is sort of hanging out could this be a problem ? any ideas peeps would be great
thanks
Old May 19, 2007 | 05:00 PM
costina's Avatar
costina
Live long and prosper!!
Fuse box that would be my guess excess water can enter the gasket check all drain holes in the scuttle area
Good luck
Old May 19, 2007 | 05:47 PM
Answered on other thread!!
Old May 19, 2007 | 06:33 PM
rabmc's Avatar
rabmc
chowfornow
14
Jan 5, 2019 09:01 PM
steve.rst
Mar 15, 2016 08:01 AM
mk1turboestate
Dec 2, 2015 08:31 PM
mpilk
Sep 27, 2015 09:21 AM
