whats the best chip to get for a series 2
Old Sep 20, 2004 | 02:05 AM
escort1989uk's Avatar
escort1989uk
Default whats the best chip to get for a series 2
as a first chip as i don't want to get loads to get the best
Old Sep 20, 2004 | 02:14 AM
RSrussell's Avatar
RSrussell
A custom chip based on your spec
Old Sep 20, 2004 | 02:17 AM
escort1989uk
and where would i get that from then as i might just say sod it and save the dollar up and go cossie managment but then i don't know who i would use probably jano
as he get's good reports and seems sound when i have spoke to him at meets
Old Sep 20, 2004 | 02:23 AM
RSrussell's Avatar
RSrussell
For a custom chip
Stu @ MSD
Karl @ NMS
Ahmed @ Grove
there are others
Or if your going cossie management, you could use
Gadget
Dingy
Zoo motorsport
Old Sep 20, 2004 | 02:29 AM
escort1989uk
so if you were think on my line who would you use for both chip and cossie managment
Old Sep 20, 2004 | 02:31 AM
RSrussell's Avatar
RSrussell
I bought all the cossie management bits myself, with the help of Gadget. And i was going to get him to fit them and Ahmed to do me a map.
But i saw sense and broke the old beantin
escort1989uk
so what happen to all the cossie parts
Old Sep 20, 2004 | 02:34 AM
RSrussell's Avatar
RSrussell
sold them
total cost around a grand, for all you need.
Old Sep 20, 2004 | 02:36 AM
escort1989uk
shit really might just pay jano for the work then as i thought i could collect the parts of flea bay could you p.m me a full list of the parts needed please
Old Sep 20, 2004 | 02:44 AM
RSrussell's Avatar
RSrussell
I can't remember all the bits off my head, have a trawl through fiestaturbo. com and the rsownersclub, as it was posted a few times.
I don't think you could get the bits cheaper off jano tbh. That included L8 ecu, 2wd loom, 4x4 tps, 803,s, 3 bar, cam trigger system etcetc.
Old Sep 20, 2004 | 02:46 AM
escort1989uk
what s a cam trigger system or am i being :blonde:
Old Sep 20, 2004 | 03:01 AM
RSrussell's Avatar
RSrussell
its a camshaft position sensor
also you need an 1800cvh timing ring and crank sensor
Old Sep 20, 2004 | 03:05 AM
RSrussell's Avatar
RSrussell
Originally Posted by Gadget
Weber management conversion parts list.
Cossie Ecu
Cossie engine loom
Cossie air charge sensor
Cossie coolant sensor
Cossie throttle sensor ( PF01 if L6 ecu or PF09 if L8 )
Cossie idle speed control valve ( and remote housing if using ERST throttle body )
Cossie throttle body or ERST one works just aswell
Cossie ignition amplifier and heatsink
Injectors ( dependant on engine spec )
Map sensor ( dependant on engine spec )
Efi inlet manifold - FRST / XR2i / XR3i ( will need some welding and re tapping to fit parts )
Efi fuel rail and fuel pressure regulator
Efi cylinder head or Mfi to Efi adaptor plate ( Grove Garage £100, 01708 726518)
Camshaft position sensor and brackets ( I can supply for £60 )
Cranshaft position sensing equipment;
Can use modified original bottom pulley or
1800 Cvh bottom pulley with timing ring ( 36 – 1 teeth )
1800 Cvh crank sensor and bracket
1800 Cvh alternator pulley
1800 Cvh alternator belt
1800 Cvh alternator bracket and adjusting arm
Note, all the 1800 Cvh parts require slight modification to fit and work.
Modifications needed for weber parts
Air charge sensor - M14 x 1.5mm thread
Coolant sensor -
Alternator brkt - 4mm machined off driver side to line up with crank pulley
Remove spacer between fan and pulley on alternator
Pull off pick up ring on crank pulley and smooth out so it spins freely, remove all teeth except 4 at 90 degrees to each other, add 2 grubs screw to lock it
5mm washer / spacer needed between crank bolt and pulley ( aswell as original one )
Cut down 1800 cvh crank sensor brkt just above the bottom fixing holes
Manifold needs welding and shaping for throttle body
Loom.
Crank sensor - swap the 2 wires round in the plug if using EEC sensor
Cam sensor - swap the 2 wires round in the plug if using EEC sensor
Very simple conversion to do, works very well!!
Old Sep 20, 2004 | 03:11 AM
escort1989uk
can you p.m me that list so i can save it on my p.m email it would be better to kirikit@aol.co.uk
tankybaby66
Feb 6, 2016 02:24 PM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
