Tuning a 2wd
Old May 18, 2007 | 07:19 AM
JanDK's Avatar
JanDK
Default Tuning a 2wd
Hi...
My mate drives 2wd Cosworth and will go from stage1 to stage2... The chip is made for T34 and ofcause greens. Will it be way out in the woods to run his present T3 with this stage2 kit fitted until he get hold of a T34? Will it be ok without blowing the engine??
Or no way around... no stage2 until the T34 is in the garage ready to fit??
Anyone??
Thanks
Old May 18, 2007 | 01:03 PM
JanDK's Avatar
JanDK
anyone at all??
I do know the very right thing to do is wait... but is it safe to run the T3 for some time??
Old May 18, 2007 | 02:26 PM
cozmeister's Avatar
cozmeister
More boost Igor!
The T3 will at the limit at 20psi, and of course the yellow injectors are running full duty cycle at stage 1 w/15psi.
The chip's map is designed for the behaviour of the turbo it's gonna be used with, so really he either needs a stage 2 chip for a T3, or a T34 to use his stage 2 chip.
Old May 18, 2007 | 02:39 PM
JanDK's Avatar
JanDK
Okay... We are aware of this... but what my mate would to do, until he have bought his T34, is fit greens, 3 bar mapsensor and stage2 chip, and drive with he T3 with what ever boost it makes. If it does not blow anything up.
But if it is completly dum.. then he must wait until he have the money to buy his T34 that fit the chip.
Thanks
Old May 18, 2007 | 03:22 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Best option is to wait for the T34
Old May 18, 2007 | 05:14 PM
rinus_2005's Avatar
rinus_2005
won't blow in a few days i guess.
Old May 19, 2007 | 06:51 AM
JanDK's Avatar
JanDK
Thank you guys .... not worth risking it!!
Old May 19, 2007 | 05:57 PM
This is bollocks 15 psi is 15 psi, the engine doe snot know if it is a leaf blower providing the air or a turbo off a ocean liner, the pressure prouced is what counts, measured by the map sensor and added fuel accordingly!!
The window of the turbo is different but AFR will remain safe, so long as max boost not exceeded.
Old May 19, 2007 | 06:53 PM
rinus_2005's Avatar
rinus_2005
oops, i'll take it all back then...
Old May 19, 2007 | 07:38 PM
JanDK's Avatar
JanDK
thanks again )
mark r
Sep 29, 2015 07:27 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
