parking light flickering on and off
Old May 17, 2007 | 09:20 PM
beef2001's Avatar
beef2001
Boost it
Default parking light flickering on and off
for some reason when im driving along the handbrake/parking light is flickering on and off im told this is due to the handbrake switch but where is it located so i can clean it up? anyone got any ideas ..
Old May 18, 2007 | 05:45 PM
Phil DJ's Avatar
Phil DJ
Just under the handbake lever I think, or somewhere around there anyway
Old May 20, 2007 | 10:33 AM
Oranoco's Avatar
Oranoco
Check the level of your brake fluid first
Old May 21, 2007 | 12:49 PM
beef2001's Avatar
beef2001
Boost it
Cheers ill have a look brake fluid is fine
Old May 21, 2007 | 05:04 PM
Oranoco's Avatar
Oranoco
Wasn't being funny with you. The handbrake light also acts as a brake fluid level warning light. When the level is lower, as the fluid moves about this can cause the light to flicker
Old May 21, 2007 | 09:53 PM
beef2001's Avatar
beef2001
Boost it
ok cool, but if i check the fluid and its topped up fine where shall i look next for the switch under the brake lever? also for some reason my fuel guage completely drops to empty when im travelling over 60mph but when i slow down to 50 it gives the correct reading again, somebody said it cud be a dodgy sender unit which is located in the fuel tank maybe this is linked. any ideas?
Old May 22, 2007 | 09:58 AM
PekaRs1800's Avatar
PekaRs1800
Its more then likely the brake fluid level.
Old May 24, 2007 | 08:47 PM
hugh janass's Avatar
hugh janass
When i got mine it was doing this...........fluid level was low.
Old May 26, 2007 | 07:07 PM
beef2001's Avatar
beef2001
Boost it
thanks for ur help guys, i checked the fluid level it well above the minimum mark but the black screw cap thing seeped a little till i really tightened it, i reckon with the car makin its natural rocking movents its possible the fluid may for a short moment drop below the predetermined sensor level therefore thinking its low or giving me a warning perhaps no moans there how much do u need ur brakes lol
IainRS1700T
Sep 25, 2015 06:44 AM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
