RST judders under braking
Old May 15, 2007 | 05:53 PM
PeteS2RST's Avatar
PeteS2RST
Default RST judders under braking
ieplaced my front brake discs and pads about 6 months ago and now after rebuilding the engine over the winter i've started to use it again and i get a judder through the pedal when i brake.The judder appears to be from the drivers side. I have taken the discs off and checked the hubs to make sure they were mounting correctly and i've also had the discs checked for any warping and there was only 2 thou run out. What else could be causing this??
Any ideas
Old May 15, 2007 | 06:16 PM
tonto's Avatar
tonto
Swop the discs from left to right and see if the judder now comes from the passenger side.You'll know then if it is the discs or not.
Paul
Old May 15, 2007 | 07:55 PM
SafeChav's Avatar
SafeChav
it can only really be the brakes to be honest.
The warp may only be 2 thou but thats still enough to cause problems.
This may help
http://www.pumabuild.co.uk/skimming.htm
Old Jun 9, 2007 | 07:02 AM
simmonjane's Avatar
simmonjane
Hi i had the same problem on my mitsubishi gto brand new racing discs and red stuff pads i had them checked and they were very slightly warped but enough to make car judder under braking, i was told to just run them in and eventually it stopped after about 3 month..
Dont know if this will be the case with your car though!!
Old Jun 9, 2007 | 08:40 AM
saff cosworth's Avatar
saff cosworth
i'd say its the discs, but check the hubs too...
A.t.p
Oct 23, 2015 07:54 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
