ARP stud nut kit
Old May 15, 2007 | 04:32 PM
mk4gartrac's Avatar
mk4gartrac
Default ARP stud nut kit
Just bought an ARP stud and nut kit to clamp the head down nice and tight just wondering if anyone has any advice on tightening sequance and torque settings?
Old May 15, 2007 | 05:05 PM
SafeChav's Avatar
SafeChav
if im not mistaken ARP products come with instructions.........?
Old May 15, 2007 | 05:19 PM
mk4gartrac's Avatar
mk4gartrac
They do but i have read lots of conflicting things and i just want to be sure im doing the right thing
Old May 15, 2007 | 05:24 PM
SafeChav's Avatar
SafeChav
well i personally would say ARP know more about their fasteners than anyone else
Old May 15, 2007 | 06:08 PM
mk4gartrac's Avatar
mk4gartrac
Has anyone fitted a head using this kit?
Old May 15, 2007 | 06:21 PM
mk4gartrac's Avatar
mk4gartrac
I have been told to torque the head to 80blf in the usual sequence and forget the 180 turn??????????
Old May 15, 2007 | 07:46 PM
SafeChav's Avatar
SafeChav
what does the instructions say?
Old May 15, 2007 | 07:56 PM
mk4gartrac's Avatar
mk4gartrac
Use manufacturers torque sequence but do not use the engine manufacturers torque specs.Torque the nuts to 80ft.lbs
But the manufacturers sequence says after torqueing to turn through 180degres.I have read that this then overloads the head gasket (due to bolts no being stretch bolts)and to just torque it down to the 80ft.lbs
Old May 15, 2007 | 07:58 PM
SafeChav's Avatar
SafeChav
torque sequence is the order you tighten the bolts in, the torque specs are the tightness of each one..........
Old May 15, 2007 | 08:01 PM
Barry R's Avatar
Barry R
that means tighten from the middle out
9 3 1 5 7
8 6 2 4 10
ex side
Old May 15, 2007 | 10:10 PM
sailorbob's Avatar
sailorbob
Tightening sequences taken from the Cosworth workshop manual;
3 dr & 2wd Sapphire:
ex side
9 5 1 3 7
8 4 2 6 10
in side
4wd Sapphire & Escort (both large and small turbo) :
ex side
9 3 1 5 7
8 6 2 4 10
in side
If you are using the 190000 psi, 12 mm ARP stud kit you only torque the nuts up to 80 ft lbs when using ARP's moly assembly lubricant.
Old May 15, 2007 | 10:16 PM
Barry R's Avatar
Barry R
9 3 1 5 7
8 6 2 4 10
ex side
this is correct for a rs turbo.
Old May 16, 2007 | 05:09 AM
mk4gartrac's Avatar
mk4gartrac
Thank you sailorbob thats all i needed confirming.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
little bram
Sep 27, 2015 07:45 AM
