S1
Old May 14, 2007 | 11:50 PM
Barry R's Avatar
Barry R
Default S1
How low can i go & whats the best height, im running on 15s
Old May 15, 2007 | 12:00 AM
T28 RST's Avatar
T28 RST
Ok then
25 - 40mm
Old May 15, 2007 | 10:13 AM
JesseT's Avatar
JesseT
Two very separate questions there. You can go as low as -60mm. The best height, however, is around standard.
Old May 16, 2007 | 12:35 PM
Barry R's Avatar
Barry R
cheeRS i wanted to go ex low but wasnt sure if it would f*ck anything up.
Old May 16, 2007 | 08:34 PM
NUTS RuS's Avatar
NUTS RuS
It will mess everything up yes, unless you have some adjustable components to un fuck it
Old May 16, 2007 | 08:57 PM
Barry R's Avatar
Barry R
i will stick to me 40mm then
Old May 16, 2007 | 09:10 PM
NUTS RuS's Avatar
NUTS RuS
-40 is just about on the limit of it remaining useful
Old May 16, 2007 | 09:11 PM
timturbo's Avatar
timturbo
ive bin lookin for 60mm springs on koni adjustables
would it rub on arches and handling wise what will it be like?
Old May 16, 2007 | 09:27 PM
NUTS RuS's Avatar
NUTS RuS
Inner edge tyre wear will increace dramatically unless you fit adjustable TCA's to compensate.
Arches and steering lock depends on tyre profile
Old May 16, 2007 | 09:36 PM
timturbo's Avatar
timturbo
195/50/15 or might be running 205/45/16 what would handling be like?
