sierra bottom pulley,does this look right???
Old May 14, 2007 | 06:57 PM
bassy_g's Avatar
bassy_g
Default sierra bottom pulley,does this look right???
i have yet to fit the alternator belt since i need to source a long bolt to fit through the alternater bracket,but looking at this picture it seems that when fittet the cps bracket would foul the alternater belt have i fittetd something worng?
thanks
Old May 14, 2007 | 07:08 PM
Rick's Avatar
Rick
that looks fine - you do know that you have to use the sierra alternator bracket, which needs modifying slightly?
Old May 14, 2007 | 07:14 PM
bassy_g's Avatar
bassy_g
it just seems so close like the belt will catch,i have the alternater bracket on from the sierra and had to grind a bit off to line the alternater up,but the bloke i bought it off didnt have the long bolt,cant get my belt on till i find a replacememt
Old May 14, 2007 | 07:30 PM
Rick's Avatar
Rick
it doesnt catch, as the belt runs under the cps bracket. You'll need a spacer washer to take up the tension when tightening the bolt up - to replace what u have ground off.
Old May 14, 2007 | 07:48 PM
bassy_g's Avatar
bassy_g
thats good no know thanks mate was worried about that one.
Old May 14, 2007 | 07:55 PM
bassy_g's Avatar
bassy_g
do you know what size the bolt is mate?im about to order a bolt but i dont understand the sizes
is it m6?
Old May 14, 2007 | 10:43 PM
SafeChav's Avatar
SafeChav
It's M8, 13mm head and 13mm nut on the other end
Old May 15, 2007 | 03:52 PM
bassy_g's Avatar
bassy_g
thanks mate,was desperate and ordered before i read this thread though,got m6 and m8 to make sure though
jonfoc
16
Sep 11, 2018 05:35 PM
nico12
Dec 31, 2015 04:42 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
dombanks
Sep 21, 2015 08:38 PM
Fudgey
Sep 17, 2015 01:06 PM
