2WD Saff g/box?
Old Jan 11, 2004 | 12:22 PM
JamesH's Avatar
JamesH
Default 2WD Saff g/box?
It seems very sticky sometimes its got a standard ford item (clutch & gearbox)
Any ideas?
Stg2 BTW
Old Jan 11, 2004 | 02:16 PM
mines a bit like that mate.
could be a sign that the syncro rings are gettin a bit old.
Old Jan 11, 2004 | 03:19 PM
JamesH's Avatar
JamesH
Yeah thats why i'm asking cos I don't know what it is and little things like this bother me
The clutch and 'box are both fords
Old Jan 11, 2004 | 04:33 PM
Hi James nice to see you posted it up for me
(I'm his dad)
Old Jan 12, 2004 | 04:35 PM
JamesH's Avatar
JamesH
Old Jan 16, 2004 | 12:49 PM
JamesH's Avatar
JamesH
you're not telling me some one does not knwo a definate answer
Old Sep 9, 2004 | 07:29 PM
blaazer2's Avatar
blaazer2
not sure what the question is but the 2wd box is actually a mustang box if it is sticky its either borc rings ,synchro hubs or clutch pressure plate not clearing properly ,the clutch its self as far as i can see is a transit petrol
Old Sep 12, 2004 | 05:25 PM
cossiedaz's Avatar
cossiedaz
wat causes the pressure plate not to clear properly as i suffer from this problem quite a lot myself. i find it extremely hard to get gears sometimes and it ruined my last outing at the pod
Old Sep 12, 2004 | 07:16 PM
blaazer2's Avatar
blaazer2
the diaphram becomes distorted if the clutch has been hot ,symptoms are ...normally ok when engine is cold but at running temp gears become notchy and it will crunch in reverse due to the fact the gearbox hasnt stopped spinning after depressing the clutch
Old Sep 13, 2004 | 12:27 PM
Spiky's Avatar
Spiky
what oil are you using????
mark r
Sep 29, 2015 07:27 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
ajamesc
Sep 27, 2015 02:25 PM
Russ Payne
Sep 25, 2015 08:29 PM
