changing from mfi to efi
Old May 14, 2007 | 01:08 PM
gaz g's Avatar
gaz g
Default changing from mfi to efi
i currentky run mfi but have just got every thing to set up efi, rebuilt head custom loom 195 chip efi inlet. everything but the bottom end . i want to keep mine as it was only nuilt last week what do i need to do about the cronk sensor . is there some way around it without drilling my block. all help and advice will be great as im gatting pissed off now
cheers garry
Old May 14, 2007 | 05:43 PM
timturbo's Avatar
timturbo
gotech mfi you will not need the block to be taken out for crank sensor as long as you have efi inlet, fiesta air filter, and wateva injectors u want run it can run efi. thats what im going to do
Old May 14, 2007 | 06:16 PM
Barry R's Avatar
Barry R
Can i have some more info pleases like eveything i will need
Old May 14, 2007 | 11:15 PM
SafeChav's Avatar
SafeChav
i don't think he's going to fork out for gotech after buy all the EFI bits
You have a couple of options, Sierra 1800 crank pulley setup, or you can buy an aftermarket trigger wheel and bolt it to your standard bottom pulley.
If you want to go the Sierra route i can source the parts for you
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
