external wastegates
Old May 13, 2007 | 03:52 PM
NEWTON's Avatar
NEWTON
Default external wastegates
what size wastegate would i need to run 2 bar thanks
Old May 13, 2007 | 03:55 PM
big_wig_074's Avatar
big_wig_074
surely you need to know what turbo and engine first?
Old May 13, 2007 | 04:01 PM
NEWTON's Avatar
NEWTON
sorry, im thinking of a gt30r with tubular manifold,i have an s1 all steel bottom mend 1.6,it make 253 atm so want more power its on gotech 803s etc etc
Old May 13, 2007 | 04:04 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
External gate isnt really needed is it
Christain made 351hp on a standard manifold and internal gate
Old May 13, 2007 | 04:11 PM
NEWTON's Avatar
NEWTON
so you think i should go for a gt30r with an internal gate
Old May 13, 2007 | 04:13 PM
big_wig_074
it would be a LOT easier,and easier to live with too!
Old May 13, 2007 | 04:15 PM
NEWTON's Avatar
NEWTON
how do you mean,with cost etc?
Old May 13, 2007 | 04:37 PM
big_wig_074
cost and you dont go deaf eveytrime it comes on boost!
Old May 13, 2007 | 09:41 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
just cause its got an external gate dont mean its got a screamer.
if money wasnt a huge issue id go external on most big power setups if i could as its a more efficient (exhaust gas flow) setup.
BUT at the same time if i could save money by using a perfectly adequate standard manifold or whatever, that makes sense.
what power you want? 500bhp+ rated GT30 for a 1.6litre 350bhp engine is a bit silly.
and gate size is mostly down to how LOW you want the boost to be able to set, the bigger the turbo and lower the boost you need, the bigger gate you need.
but TBH there not REALLY such a thing as too big, so id just get a 50mm Turbosmart job and be done with it.
Old May 14, 2007 | 07:22 PM
NEWTON's Avatar
NEWTON
and gate size is mostly down to how LOW you want the boost to be able to set, the bigger the turbo and lower the boost you need, the bigger gate you need.what turbo do you reconmend?
Old May 14, 2007 | 07:23 PM
NEWTON's Avatar
NEWTON
May 31, 2016 09:28 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
RSBryden
Sep 6, 2015 08:39 PM
Aug 14, 2015 07:29 AM
