SAFC tuning
Well i dont know what your like with electronics but I found it a piece of piss and just went up the road with a wideband.
does what it says on the tin really, you have RPM points and you can adjust the fuel for each one (think its around 12 ish but dont quote me on that)
You can lean the mixture off boost and then wack more in when on boost.
you need to give it rpm, inj duty and AFR signal IIRC, worked well with a Z32AFM on my SR20DET..............what engine is it for?
SMILER258
Sep 28, 2015 09:04 AM
