Plumbing in oil pressure gauge on cossies...
Old May 13, 2007 | 12:23 PM
boXXer's Avatar
boXXer
GASH!
Default Plumbing in oil pressure gauge on cossies...
Where abouts? and what line?
Cheers!
Old May 13, 2007 | 12:26 PM
mechanic28's Avatar
mechanic28
easy my man u get a T peice for it remove the oil pressure switch (located on the block under the inlet manifold)but the T peice in the block then fit the guage pipe to the T peice and fit the oil pressure switch to the T peice job jobbed
Old May 13, 2007 | 12:49 PM
Andreas's Avatar
Andreas
Got my Y-piece at the local Ford dealership, quite cheap (£15), think its from the Escos and give better clearance than a T-piece.
Old May 13, 2007 | 01:04 PM
St3V3_C's Avatar
St3V3_C
Could be, as there is one fitted as standard
Old May 13, 2007 | 01:07 PM
boXXer's Avatar
boXXer
GASH!
cheers guys. Do you know the finis code of the y piece?
Old May 13, 2007 | 02:43 PM
RS500/364's Avatar
RS500/364
Remember you was going to have the fiiting from me !!
Old May 13, 2007 | 05:59 PM
boXXer's Avatar
boXXer
GASH!
oh yeah, lol. So i was! are you going to any meets soon?
Old May 13, 2007 | 06:28 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Boxxer r&b motorsport do them to mate, i called up the other day as i have 2 of them one tapped into the other, i want to just have one tho as its tight, he didnt have any in stalk but is getting them some time during the week
Old May 13, 2007 | 10:11 PM
boXXer's Avatar
boXXer
GASH!
cheers bud.
Old May 13, 2007 | 10:38 PM
Jimboxr4x4's Avatar
Jimboxr4x4
I tried a t-piece from demon tweaks and also R&B and neither gave enough clearance when using an electric oil pressure sender (for a Tim gauge). In the end I bought a remote t-piece on the end of a 2 foot pipe. Much better way of doing it as its pretty cramped by the take off on the block.
Old May 14, 2007 | 06:08 AM
dojj's Avatar
dojj
Resident Wrestling Legend
get a lenght of braided hose to move the t peice location further away from where it is
simple enough really
or get one of them oil presse things that slot inbetween the filter and block that i saw somewehre a few weeks ago
Old May 14, 2007 | 06:21 AM
RS500/364's Avatar
RS500/364
you need the long verson for the electronis presure sensor
not many know that
and boxer at surrey all the time and mid
Old May 14, 2007 | 11:18 AM
boXXer's Avatar
boXXer
GASH!
well, i use a electronic sender for a SPA gauge, so will it work?
dojj Not that easy mate. My s1 currently has the sandwich plate setup, but on cossies they have a oil cooler before the filter already, so i dont think there would be enough room for another plate in there.
Old May 14, 2007 | 11:49 AM
rsnissan's Avatar
rsnissan
Mike i have one of these for my SPA sender, from Think auto IIRC who aren't far from you
Old May 14, 2007 | 12:35 PM
dojj's Avatar
dojj
boXXer
you'll need the longer line this then
i've got the spa stuff on mine too, and the sender is about the size of a bigmac
Old May 15, 2007 | 08:47 AM
boXXer's Avatar
boXXer
GASH!
What thread size is the block then? as the sender 1/8th bsp. Are they all the same? also, is there a way you could take the temp from here aswell? didnt really wanna drill a hole in my sump.
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
Brickhouse
Sep 21, 2015 11:00 AM
coscor86
Sep 20, 2015 01:21 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
