zvh headgasket??????????? conversion questions???? help plz
Old May 12, 2007 | 07:18 PM
rosie's Avatar
rosie
Default zvh headgasket??????????? conversion questions???? help plz
i have a 2.0 zvh engine removed from an rs turbo & i am doin the headgasket before i fit it into my xr2.
do i just use a standard rs turbo headgasket????????? or is there a special one for the zvh?
also im unsure what pistons are fitted in it, if they are standard zetec ones can i have them skimmed them down 2 lower the compression?????
also a pic of the engine mount modification would be helpfull if any1 has it or a link to a webiste showing how 2 do conversion?
cheers
Old May 12, 2007 | 07:31 PM
SafeChav's Avatar
SafeChav
the only gasket to use for those is a felpro one because of the bore size and mis-match of a CVH head.
I have the correct gasket for the job i believe if you are looking to buy one......
Old May 12, 2007 | 07:36 PM
rosie's Avatar
rosie
ive found the engine mount pic now.
are these the same head settings as a cvh then?
Old May 12, 2007 | 08:05 PM
zippyobrien's Avatar
zippyobrien
if the engines been in a s2 rsturbo, then it will already have had the mount chopped.
Old May 12, 2007 | 08:09 PM
rosie's Avatar
rosie
yes but i dont have the mount, also im sure xr2 mounts are differnt from escort
Old May 12, 2007 | 08:11 PM
zippyobrien
but they locate on to the engine in the same way, so they will be modded in the same way
there was a zvh fiting guide on a xr2 in performance ford before,. can try to get that mag
Old May 12, 2007 | 08:12 PM
SafeChav's Avatar
SafeChav
look on the quantums site it shows everything you could ever wish to know
Old May 12, 2007 | 08:17 PM
rosie's Avatar
rosie
yer just found that for mount pic
mk3ste
Oct 17, 2021 10:09 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
