non starting rst
Old May 12, 2007 | 08:53 AM
marshy3563rst's Avatar
marshy3563rst
Default non starting rst
hi i have an rst s2 that wont start as i turn it over over it starts for a few seconds then dies any body have any ideas cheers paul.
Old May 12, 2007 | 11:42 AM
tonto's Avatar
tonto
Hi,Sounds like your fuel pump isn't working.Get someone to listen to the fuel tank when you try to start the engine.You should here the pump if it is working.If its not it will more than lightely be the big pink relay in the fuse box.
Paul
Old May 12, 2007 | 11:50 AM
marshy3563rst
i have put a new fuel pump on recently i dont have a pink relay in my fuse box what other colour could it be
Old May 12, 2007 | 12:00 PM
tonto's Avatar
tonto
Can u here the pump working when trying to start the engine?
Paul
Old May 12, 2007 | 12:13 PM
marshy3563rst
yes u can here it prime when the ignition is turned on.
Old May 12, 2007 | 12:15 PM
tonto's Avatar
tonto
But can u here it when cranking the engine?
Paul
Old May 12, 2007 | 12:22 PM
marshy3563rst
yea it stays on while cranking
Old May 12, 2007 | 12:33 PM
tonto's Avatar
tonto
All I can think of whithout being with the car,is either the fuel filter is blocked thus only giving a bit of fuel allowing the engine to run for a bit,Or the fuel pressure is very low.When changing fuel pumps the pressure needs to be set at the regulater.
Paul
Old May 12, 2007 | 04:24 PM
marshy3563rst
i have put a new fuel filter how do u reset the regulater cheers paul.
Old May 12, 2007 | 04:34 PM
tonto's Avatar
tonto
You need a friend who is in the trade.To adjust the fuel pressure a fuel pressure gauge is required.Again I am only guessing.I've run out of suggestions now. sorry mate.
Paul in sunny Newport.
Old May 13, 2007 | 12:34 AM
rst230bhp's Avatar
rst230bhp
Mate the pink relay is under the dash, not in the fusebox, or have i just read it wrong
Old May 13, 2007 | 05:35 PM
marshy3563rst
i have put a new fuel relay still wont stay runnin dies after a few seconds.
Old May 13, 2007 | 06:27 PM
johnnysash's Avatar
johnnysash
could it be a slight air leak from one of the hoses? have you got a dump valve fitted? does it run if you rev it up? Can you keep it running by pouring fuel down the metering head (not too much! unless you like fires!)
were there any other problems before this started happening?
Old May 13, 2007 | 07:58 PM
marshy3563rst
carnt c any air leaks checked all of them it started to run lumpy for a couple of days then just stopped and wont start again no matter how much i put my foot on the gas. its been like it now for a couple of weeks and its baffling me dnt matter what i try just dont wanna go.
Old May 13, 2007 | 09:38 PM
Barry R's Avatar
Barry R
wanna sell it
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
