Auto Gearbox Flexplates
Old May 11, 2007 | 03:41 PM
Cossiep's Avatar
Cossiep
Default Auto Gearbox Flexplates
Does anyone have any experience with these ?
Just been informed that my flexplate has cracked, I understand the principle of the flexplate and torque convertor, however if these two parts fail does that render the whole box scrap ? (as this is what I'm being told)
Just wondering if I'm getting mugged off ?
Any advice appreciated
Old May 11, 2007 | 03:44 PM
Absolute bollocks you are being told mate.
I have always had auto cars, tuned as well, and cracked/broke a few plates, well three in 25 years, one was a x flow at 180bhp though with original 1300 flex plate.
Why do you think yours is cracked ?
What car/box is it.
Old May 11, 2007 | 03:47 PM
Cossiep's Avatar
Cossiep
Tabetha
Merc E280 W210 chassis, been told the flexplate has cracked, due to running out of line
Old May 11, 2007 | 04:16 PM
What are the symptoms ?
Was the gearbox always attached to the engine ?, how could it be out of line ?
Cracking is very very rare.
Old May 11, 2007 | 06:34 PM
dave green's Avatar
dave green
Dont no about Merc flex plates, But its not rare for ford flex plates to crack , Torque converter failer is the most common reason for cracking.
Symtoms is noise when reving in neutral .
Dave
Old May 11, 2007 | 07:21 PM
900ss's Avatar
900ss
RWD Racer
As Dave wrote, esp if it were a 2.3/ 2.8 Granada mk2 lol
They had a habit of cracking around the crank/ bolt area.
Eventually you end up wit no drive .
Cossiep's Avatar
Cossiep
Symptoms were as Dave has pointed out, however does a failed torque converter and flexplate ALWAYS = knackered box ? or is every case different ?
Old May 11, 2007 | 08:51 PM
dave green's Avatar
dave green
Box should be OK , Replaced loads of flex plates and convertors together never had a problem with the gearbox
Dave
Old May 12, 2007 | 01:02 AM
Boxes always survive, most flex plate cracks are due to idiots not COMPLETELY STOPPING when they change direction.
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
AJC
Oct 1, 2015 06:47 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
