Gauge importance, volts, oil temp or water temp
What do people consider the most important out of the title list to monitor on a track car ?
I already have Oil press, AFR, boost and inlet plenum temp, but am considering one last item. Had initially though Oil temp but not sure.
What do you guys and gals suggest.
cheer
Dave
cheer
Dave
Originally Posted by tabetha
OIL TEMP + OIL PRESSURE.
You can do without the others how long do you think you will spend looking at them ?
As for volts and the others listed, don't waste your time
EGT gauge
Voltmeter
Oil Pressure
Oil TEmp
Water Temp
Boost
AFR Gauge
oil pressure is a must i think
i have
boost
volts
oil press
oil temp
afr gauge
and charge air temp gauge
dont see the point in egr on a road car unless you have anti lag
track car yes and no i think
i have
boost
volts
oil press
oil temp
afr gauge
