Alternator running off something else aside from the engine?
Can you? And how? Rear diff? Guess there no other way of generating electric for an engine aside from that is there?
Anything that rotates would work in a fashion, but stuck in traffic with rad fans on would drain the battery quickly. Better remember to switch the engine off when stationery
doesn't have to be driven from the front of the engine. there are many production engines that have one accessory behind another driven by a straight through shaft.
how about the input shaft of the gearbox? or mounted similarly to the starter motor and driven by the flywheel ring gear (although that would be bloody fast
or you do away with the alternator all together and use solar panels
)or you do away with the alternator all together and use solar panels
remember seeing a brown 3 door in holland with the transmission tunnel cut into for this. Believe the reasoning was to put less immediate work on the engine, car was a track/strip car. Obviousley you dont get anything for nothing and the engine would still somewhere down the line be creating energy to drive the alternator just it would be geared up through the gearbox. Dont think this particular car needed it for space saving as the engine had been moved back already (unless cossie alternator is on rear, not sure, only played with cvh's).
big_Rad
Sep 15, 2017 09:36 AM
Zoggon
Aug 10, 2015 10:39 AM
lockie
Jul 31, 2015 10:03 PM
