rs2000 I4 lump to rwd
Old May 10, 2007 | 08:26 PM
AlexF's Avatar
AlexF
Default rs2000 I4 lump to rwd
what flywheel, clutch and box would be needed?
ta!
Alex
Old May 10, 2007 | 08:31 PM
Jasesapphy's Avatar
Jasesapphy
MT75 from Sierra 2wd DOHC, Sierra DOHC Clutch, Sierra 2.0 DOHC Fly wheel, i reckon as it is the same bottom end
Old May 10, 2007 | 08:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
as said
so don't pester me on msn again when i'm enjoying the delights of pornography
Old May 10, 2007 | 08:51 PM
Graceland's Avatar
Graceland
Team HOTHOT!
You also need a remote thermostat housing - I made mine using a Cologne 2.9i v6 housing modified to mate to the original thermostat housing and another Cologne 2.9i v6 thermostat housing to take the feed off the back of the head
Old May 10, 2007 | 08:53 PM
AlexF's Avatar
AlexF
cheers
Old May 10, 2007 | 08:56 PM
Jasesapphy's Avatar
Jasesapphy
Get a scorpio 2.0 head, and run the RS2000 cams e.t.c, the thermostat housing is on the front then as its a longitude engine as standard
Or do as Gracey
Old May 10, 2007 | 08:57 PM
dojj's Avatar
dojj
Resident Wrestling Legend
or you can find a 16V scorpio and use the inlet from that
Old May 10, 2007 | 08:58 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Scorpio inlet won't fir the rs2000 head as the coolant channel has not been ported for rwd on the rs2k head
Old May 10, 2007 | 09:03 PM
rs_daz's Avatar
rs_daz
What ya building mate lol
Old May 10, 2007 | 09:05 PM
James's Avatar
James
orrr buy a scorpio!
Old May 10, 2007 | 10:35 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
what you up to
Old May 11, 2007 | 12:24 AM
kitchy's Avatar
kitchy
RS2000 4x4
get a 2.3 scorpio engine, alreayd ready for RWD and use RS2000 cams and the like more power and torque that way
Old May 11, 2007 | 05:55 AM
dojj's Avatar
dojj
some people say that the scoprio and rs2k cams are the same..................................
but there is a 2.3 complete just down the road from me at a scrapyard who'll pull it out for you for Ł250
be aware that if you go 2.3 the flywheel and clutch are totaly different to the 2.0 versions, and trying to find a manual 2.3 is a bit tricky
been there, done that, taken it apart, offered adivce to jim regarding bolting the 8V head on etc etc
Graceland but you did away with all that and just bolted a cossie inlet to yours didn't you
Old May 11, 2007 | 09:04 AM
SapphyMike's Avatar
SapphyMike
mine was first, but i didnt do it myself lol.
Old May 11, 2007 | 09:55 AM
Jasesapphy's Avatar
Jasesapphy
Cams are different on RS2000 and a Scorpio 2.0, i cant remember the diffrences, but i t was one of the reasons a scorpio was 136bhp and a RS200 was 150bhp
Old May 11, 2007 | 01:31 PM
AlexF's Avatar
AlexF
WHy would I bet up to anything
Old May 15, 2007 | 03:06 PM
thecrust's Avatar
thecrust
Jase, I think the cams are the same mate.
The RS2000 I4 block uses the same flat-topped pistons as the Sierra DOHC, whereas the Scorpio 2.0 uses dished pistons to lower the CR down to something like 9.5:1.
Also the RS injectors are 255cc items compared to the Scorpio's 191cc.
Given the above and the fact that the RS has a better (tubular) exhaust manifold compared to the scorp's cast item, and a more aggressively-mapped ECU, I think that could go a fair way to accounting for the differences in output - the engines are basically identical apart from the pistons IIRC.
Old Jun 2, 2007 | 11:29 PM
g68's Avatar
g68
have you got any pics of this arrangement.as i got a sweet running rs 16v im converting to put in my sierra and this is the only thing thats stumped me.
first post
russ
Old Jun 3, 2007 | 04:59 PM
Graceland's Avatar
Graceland
Team HOTHOT!
first post
russ
Nope
Prickly_buzz
Dec 7, 2017 09:52 PM
turbotrev
39
Apr 17, 2016 09:03 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
landaqmabba
Sep 15, 2015 07:16 PM
28
Sep 8, 2015 07:10 PM
