Thermostat questions
Old May 10, 2007 | 04:18 PM
Rippers's Avatar
Rippers
Monte Geek
Default Thermostat questions
On a 4x4 cos is the purpose to of the Thermostat to warm the system up quickly for the internal heater matrix on colder days?
..and when we say the thermostat opens what is actually happening does that brass bit in the middle push out or pull in?
I understand Rally cars don't use stats is there any reason why a road car can't other then the water taking longer to warm up and creature comforts?
finally does anyone have a flow diagram of the water on a 4x4 Cos engine?
Old May 10, 2007 | 04:20 PM
charlie luciano's Avatar
charlie luciano
Not too sure on what you are asking but I've been told a 4x4 cos must have the thermostat in place, its not good if it don't,
Luciano
Old May 10, 2007 | 04:31 PM
Rippers's Avatar
Rippers
Monte Geek
Would it be to get the oil temp up?
Old May 10, 2007 | 04:37 PM
Eagle's Avatar
Eagle
Super Moderator
using an engine with no stat promotes hot spots within the engine,and could lead to other issues ..
well thats what i was told when i asked
Old May 10, 2007 | 04:39 PM
Smit's Avatar
Smit
The 60ft Launch King
It's a spring! When the water gets above a certain tempurature/pressure it opens allowing water to flow to the radiator more freely
If u don't have one it can be very difficult to have warm air on the blowers and the engine water remains very cold.. (About 60-70c)
Old May 10, 2007 | 04:41 PM
Rippers's Avatar
Rippers
Monte Geek
Reason I'm asking is because I have Grp-A Thermostat housing which doesn't use a stat and has the bypass welded up
inside the housing
other side
Without the stat and the bypass welded up I'm theorising that this forces all the water to circulate through the rad? can anyone confirm?
Without the bypass welded up I could see hot spots being a potential problem?
Old May 10, 2007 | 04:42 PM
charlie luciano
Again not sure on oil, but if you take out the stat in a car it runs cool (older vehicles) ie mk 2 escort so I would imagine its purpose is an element of creature comfort as cool runnings mean heater works cack, not good in winter
Luciano
Old May 10, 2007 | 04:46 PM
Basky's Avatar
Basky
would it be better to run without one in a track or rally car etc(to keep temps down)
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
The Enigma
Sep 29, 2015 10:31 AM
