XR4X4??
Old May 10, 2007 | 04:06 PM
jay991's Avatar
jay991
Default XR4X4??
few q's as im looking at getting one soon.
what should i look out for (common probs/expensive probs)
it does need a bit for MOT so is it gonna be worth it? ie what are they worth on the road min? / breaking it for spares? / use as a track car?
cheers for any advise
James
Old May 10, 2007 | 09:51 PM
dakar's Avatar
dakar
Corrosion at the back of the sills might only look cosmetic on the outside but can be a lot worse if you start poking around.Good cars though mate if you get a goodun
Old May 11, 2007 | 06:16 PM
piranha's Avatar
piranha
when I bought mine the bottom arms were knackered, the brakes were warped, the speedo and fuel gauge was knacked all belts were brittle and needed replacing, and it had no cooling fan, apart from that it was not too bad,
jacking points are worth checking and I'd have a good look for bad arch repairs
also the fuel tanks go around the join and they can leak if you put more than £10 worth of fuel in, so i'd be ready with the jerry cans the first time you fill it, just in case
the rocker cover gaskets also usually need replacing, at least in my experience anyway
I payed £600 for mine, despite the work it needs, I think it was worth it, others may not
I've always been a believer that if it's your cash and it's what you want then sod what other people think
Old May 16, 2007 | 09:04 PM
jay991's Avatar
jay991
picked it up today... not too bad it runs and its pretty solid, was stood for about 12months in the cornish saltyness but like i say... seems to of held up well.
Old May 17, 2007 | 05:58 PM
dakar's Avatar
dakar
Just needs a T cut
Old May 17, 2007 | 08:14 PM
XR2's Avatar
XR2
should have been red a long time ago?
Old May 23, 2007 | 05:42 PM
piranha's Avatar
piranha
looks ok, besides, even if the paint doesn't come up It'd make a good sleeper. just de- badge it
72*Tina
Sep 1, 2015 10:06 PM
Jimboxr4x4
11
May 7, 2005 06:19 PM
GavinPearson
Sep 21, 2004 09:17 PM
Graceland
Apr 15, 2004 09:08 PM
