could you run an engine in reverse?
Old May 10, 2007 | 02:11 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default could you run an engine in reverse?
Just wondering after seeing chips post on gearbox's, if you turned an engine by starter the oposite way from the way it runs normally, would it run?
Old May 10, 2007 | 02:15 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yes you could, but you would need to sort the cams out too of course!
And bear in mind the thrust side of the pistons would now not be, so if you have an offset pin in the piston, it would be the wrong way
Old May 10, 2007 | 02:17 PM
vroooom ptssssh
It Wasnt Me!
Ah nice one, not that it'd be of any use!, Ive been wondering about this for ages your thread just reminded me to ask!
Old May 10, 2007 | 02:20 PM
Chip's Avatar
Chip
In the world of nitrous people do something subtley different but smilar and swap the inlet and exhaust round so that they have larger exhaust valves!
(new cams of course!)
Chip's Avatar
Chip
PS
back on the subject of the backwards engine, you would also have to move the cam tensioner ideally, but could run it without doing so
Old May 10, 2007 | 02:29 PM
vroooom ptssssh
It Wasnt Me!
Never even thought about swapping the manifolds over!
About the cams, what is it that needs changing? is it the lift on the opposite side would be too severe?
Old May 10, 2007 | 02:39 PM
Chip's Avatar
Chip
No, its the order in which they open up, although possibly on a Twink you might get away with just rotating them to a different point I guess.
Old May 10, 2007 | 03:20 PM
FasterFords's Avatar
FasterFords
Wouldn't it suck in air from the exhaust pipe and blow it out the air filter ?
Old May 10, 2007 | 03:32 PM
vroooom ptssssh
It Wasnt Me!
Ah right good point chip!
FasterFords, I think thats why chip sais the cams would have to be changed so they open at the right time!
Old May 10, 2007 | 03:37 PM
PGT's Avatar
PGT
do all engines have the crank centre line directly below the centre line of the bores?
Old May 10, 2007 | 03:38 PM
RickyLee53's Avatar
RickyLee53
This can be done much easier on a 2stroke
Doesn't change much apart from timing. (Electrical) if you start going backwards on your bike you know you've timed it up wrong
Old May 10, 2007 | 03:59 PM
JohnP001's Avatar
JohnP001
When I was younger, I used to fly string control aeroplanes, which used to use a Baby Bee engine. Some times when flicking the propeller it would start the wrong way so couldn’t fly, as the propeller would be spinning the wrong way. I would have to throw a cloth into the propeller to stop it and then restart. (Very simple 2-stroke engine.)
But my bother had a conversion on his Volkswagen camper van done in South Africa. The big rage over there in the 1980’s was to take the air-cooled engine out, and replace it with a Ford 3L V6. The only problem was that the standard gearbox couldn’t take the power/torque. People with money installed Porsche gearboxes. But he got a conversion from a company, which installed a Citroen gearbox, and then reversed the rotation of the V6 engine. If memory services me correctly, only new cams, and something in the distributor was changed. (It was a long time ago now.) The van went like shit off a blanket, and was down right scary at high speeds. After a few years, the wheel studs started distorting from the pure torque being past through them.
Old May 10, 2007 | 04:03 PM
vroooom ptssssh
It Wasnt Me!
JohnP001, @ having to through a towel onto the prob, can jus picture it! "why's the fucker not flying now" lol
Campervan sounds cool (for a campervan!)
so its deffo possible
Old May 10, 2007 | 04:05 PM
Early FIAT 126 used to do this as standard as they had no reverse in the gearbox, you had to stop the engine pull a lever and it started it up in reverse rotation.
Old May 10, 2007 | 04:07 PM
AlexF's Avatar
AlexF
It will wreck the cam drive if you don't sort out the tensioning....
you can't really claim to be controlling the cam by leaving one side flapping around and pulling against the tensioner.
Alex
Old May 10, 2007 | 04:08 PM
AlexF's Avatar
AlexF
what?!
You didn't have to do that on a Fiat 500 so why would you on a 126?
Alex
Old May 10, 2007 | 04:09 PM
Moonie's Avatar
Moonie
What about the flow of coolant?
Surley the water pump would be running backwards and therefore circulating the water the wrong way.
Madbradz's Avatar
Madbradz
Many moons ago I managed to bumpstart my Rs125 In reverse... Just to see if i could..... About 10 mins later it needed new fairings....
Old May 10, 2007 | 04:19 PM
GUZZLER's Avatar
GUZZLER
2 stroke engines run fine backwards
Old May 10, 2007 | 04:22 PM
JohnP001's Avatar
JohnP001
That is true. I'm sure there was a modified water pump that came with the conversion.
Old May 10, 2007 | 04:43 PM
Maxfield's Avatar
Maxfield
I've done this with a 4stroke bike did no harm
Bike broke the day after
Old May 10, 2007 | 08:41 PM
I'm fairly sure it was 126 fiat but not 100%, I have been in a car once that did this when I was younger about 10/12, remember thinking how ace it was to have 4 reverse speeds.
Old May 10, 2007 | 08:45 PM
kev 3dr's Avatar
kev 3dr
old diesel engines use to do it for fun if you werent careful were you parked the truck on a gradient.
big_Rad
Sep 15, 2017 09:36 AM
ekjim
Aug 17, 2015 08:57 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
lockie
Jul 31, 2015 10:03 PM
