exhaust wear
Old May 9, 2007 | 07:22 PM
beef2001's Avatar
beef2001
Boost it
Default exhaust wear
every time i go over a high road bump it scrapes a bit of the exhaust normally the curved bit at the front downpipe im concerned its gunna wear a hole in it, is there anything i can do about this?
Old May 9, 2007 | 07:24 PM
whosyadaddy's Avatar
whosyadaddy
have a plate welded over it
Old May 9, 2007 | 07:26 PM
dave cos4x4's Avatar
dave cos4x4
fix the exhaust.
don't drive over them so it hits it.
no.....undo the clamps and move it so it goes higher.
it will be the middle bit that will be rubbing,have a look and go from there.
Old May 9, 2007 | 07:43 PM
Basic question of physics, ground/exhaust if they are too close they hit.
Maybe your car is too low ?, try adjusting it first though
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
