8 injector help!
Old May 8, 2007 | 08:31 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
Default 8 injector help!
hi there, im just wandering why people stil need to use 8 injectors when 1000cc are available etc can you get morw accuracy or something? ive got 550 high imp at the mo and am just wandering which route is better for more power and out of curiosity!!
Old May 8, 2007 | 10:34 PM
LuiPoland's Avatar
LuiPoland
second injector rail mostly is installed farther then primary
fuel have longer way to the cylinder and it can vapourise better, and it have more time to
take away some heat from air and improve charge density
using only one rail far inlet valves isnt good for low revs
Old May 9, 2007 | 05:34 AM
It is nothing to do with the amount of injector rails this merely supplies the injectors.
It is the siting of the injectors, with 8 you can optimise for low speed torque, where they will fire at the back of the valve to futher away STRAIGHT down throat where they will have longer to mix being combustion, as said it also helps with latent heat absorbtion.
Advances since 8 injecotr days in the area of ECU makes this(almost) redundant now, as you can get ace fuelling across the board with large injectors as better maps are available.
Old Nov 23, 2007 | 05:20 PM
mappindude's Avatar
mappindude
4 large injectors usually make for poor emissions @ idle
Old Nov 25, 2007 | 09:50 PM
ECU Monitor Enthusiast
8 injectors are for tuners who are "stuck" in there ways or for those who
want the "bling" effect....
.... All IMO of course
Old Nov 25, 2007 | 09:52 PM
Sorry mate but not if mapped correctly by someone who knows what they are doing.
Old Nov 26, 2007 | 06:02 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
and thats coming from someone named mapping dude
Old Nov 26, 2007 | 08:23 AM
mappindude's Avatar
mappindude
like me who has got some cars to pass cat test (without a cat)
and some carbed cars for that matter.
I Speak from experience.
(not cyber experience)
The bigger the injector generally the worst the emissions will be .
I try to help people on this forum and give another opinion.
Old Nov 26, 2007 | 11:29 AM
sailorbob's Avatar
sailorbob
There are two elements that affect the ability of an ecu to control large injectors at small pulsewidths;
i) The resolution in the software to command the small pulsewidths required at idle. i.e. not all ecu's have the ability to do this.
ii) The ability of the hardware to drive the injectors open fast enough and for them to close quickly enough to produce repeatable small pulsewidths. Again, this depends on the ecu and injectors.
So, it it is not as simple as saying whether 8 smaller or 4 larger injectors is better and you need to know about the system controlling them.
Old Nov 26, 2007 | 11:31 AM
Stu @ M Developments's Avatar
PassionFords Creator
Perfect answer. Saved me replying.
Old Nov 26, 2007 | 04:43 PM
Hence my original reply
Old Dec 15, 2007 | 08:11 AM
mappindude's Avatar
mappindude
put big injectors on std weber IAW and emissions are terrible .
Old Dec 15, 2007 | 08:46 AM
A little meaningless unless you Define "BIG" mate.
Old Dec 15, 2007 | 09:20 AM
cozmeister's Avatar
cozmeister
More boost Igor!
I'd like to say "I was gonna say that" but I wasn't Makes sense to me though
Old Dec 15, 2007 | 03:13 PM
You obviously dont know what you are talking about
Old Dec 16, 2007 | 04:38 PM
DazC's Avatar
DazC
Don't think big is going to get defined!!!
Old Dec 18, 2007 | 05:33 PM
richard youll's Avatar
richard youll
daz i think he means american style injectors, you know BIG, like the people!
Old Dec 18, 2007 | 09:23 PM
DazC's Avatar
DazC
But big can mean different sizes! All big but all different!!
Old Dec 18, 2007 | 11:49 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Shall we agree that in this instance, 'bigger' means 'higher flow'?
Old Dec 19, 2007 | 07:27 PM
mappindude's Avatar
mappindude
They were greys .
On a chipped Iaw ecu. saw a few ,all had crap emissions.
but wow,this forum has some serious flamers in here dont it?.you really welcome new people dont you.
takes all sorts i guess.
Old Dec 19, 2007 | 07:36 PM
They were greys .
The greys had nothing to do with the poor emissions i assure you. It was just bad mapping.
Old Dec 19, 2007 | 07:47 PM
DazC's Avatar
DazC
These days, greys are considered as "not big".
Unless used on an RST.
Old Dec 19, 2007 | 08:03 PM
mappindude's Avatar
mappindude
they had off the shelf chips in by so called cossie specialists.
Old Dec 19, 2007 | 08:48 PM
DazC's Avatar
DazC
Thats why!
My Dad's car runs at lambda 1 on 890cc injectors and returns 30 mpg on Marelli.
Old Dec 19, 2007 | 10:02 PM
Snow's Avatar
Snow
I think your Dad should change a new one.
The car is too old.
Old Dec 20, 2007 | 08:48 PM
FROMFIFE's Avatar
FROMFIFE
Having recently had my engine re-built, I went for the WRC 8 injector route purly for emmisions. There are more and more Police carring emmision testers in their cars and because of the "Greenies" pressure fines are now quite high.
As you can argue that the car can only be tested to the same as MOT standard (on tickover) 8 injectors gives you the best chance of passing with a tuned engine.
Maybe I wasted my cash, but at least I feel safe if pulled over.
Old Dec 21, 2007 | 06:39 PM
mappindude's Avatar
mappindude
hmm.
basically someone else who didnt know what they were talkin about told you to use 8 injectors?.
Old Dec 21, 2007 | 11:51 PM
DazC's Avatar
DazC
Your emissions have as much chance of being illegal with an 8 injector set up as they do on a 4 injector set up. It's all down to the mapper and condition of the car...
Old Dec 22, 2007 | 08:49 AM
mappindude's Avatar
mappindude
Has any one done a back to back using the same car?
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
