My GF needs help(lol.. I KNO) Zetec help needed!!!!!
Old May 8, 2007 | 07:32 PM
lickshot's Avatar
lickshot
Default My GF needs help(lol.. I KNO) Zetec help needed!!!!!
hey.. first of all thanks for taking time out to read this....
right, my girlfriend has a 1.8 16v silver top zetec in her escort mk6 convertable and the lump is sounding a bit worse for wear...
I have a silver top 2.0 16v mondeo engine in my garage all complete apart from the ecu as i sold it to sum chappie on here...
My question is pretty predictable i spose... but will the mondy engine bolt straight up into/onto origional mounts?? will i need to swap over the sump?? what about the alternater bracket?? Aaaaaand will all the loom plug straight in?? can i run it on the 1.8 ecu??
I know the engine i have is sound... and id have no probs with the swap over myself aslong as everything is pretty straight forward...
All help and advice on this would be greatly apreaciated people...
Has anyone done this to their escort??
Thanks in advance my fellow ovalists!!!
Old May 8, 2007 | 07:35 PM
pee vee's Avatar
pee vee
Strip the 2lt to the bare engine..
use an 1800 oil pump and water pump
1800 sump and oil pick up pipe.
then just put it in the cabby as if it was an 1800....
it will run pretty good on the 1800 management too as its got Air flow meter,
so the fuelling will be accounted for,,
bolt it in mate.
Old May 8, 2007 | 07:41 PM
lickshot's Avatar
lickshot
Blindin fella!!! just what i wanted to hear to be fair!!!
Her lump is running stock at the mo and shld be 115ps but more like 90ps to be honest... the lump i have is a 136ps...
Will running it on the 1800 ecu affect power??
And will all the loom plug straight in 2 mondy engine???
Cheers for the reply pee vee!!
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
col93saphcos
Aug 7, 2015 03:21 PM
