S1 Cooling fan & reverse lights problem??
Old May 8, 2007 | 03:00 PM
S1Luke's Avatar
S1Luke
Default S1 Cooling fan & reverse lights problem??
Hi Folks,
Completed a top end rebuild on my ERST S1.
Since the rebuild the Cooling Fan does not cut in and the reverse lights do not work. I'm sure these are only simply fixes or things not connected up properly but if anyone has any suggestions as to what the fault is and where I can find it that would be great!
I'll post some pics of the rebuild and the car in the near future!
CheeRs,
Luke
Old May 8, 2007 | 03:06 PM
First thing is to check the fuses, as these two MAY be on the same(blown) fuse.
Old May 8, 2007 | 06:23 PM
S1Luke's Avatar
S1Luke
Will do!
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
gulliver
Ford KA
Aug 31, 2015 01:42 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Old ford
Jul 31, 2015 06:50 AM
