FRST charge carrier...
Old May 8, 2007 | 12:30 PM
JimmyBoy's Avatar
JimmyBoy
Default FRST charge carrier...
Do they come with with a ACT / IAT (Charge Temp) sensor ?
I would of thought they did, but someone told me they dont ?
Old May 8, 2007 | 01:01 PM
PeterD's Avatar
PeterD
ive only ever seen aftermarket fellas on them to be honest
EDITED to say the above applies if were talking about ACT guages but there should deffo be a charge temp sensor to the ECU.
Old May 8, 2007 | 01:24 PM
JimmyBoy's Avatar
JimmyBoy
Yeah, im talking about standard. I would of thought they come with a sensor for the ECU as standard (same as the s1/s2 does).
Old May 8, 2007 | 05:15 PM
Turbo-Beal's Avatar
Turbo-Beal
The fiesta rs turbo does have an air charge temprature sensor but its on the inlet manifold rather than the charge pipe
Old May 8, 2007 | 06:01 PM
SafeChav's Avatar
SafeChav
As above, its mounted on the inlet manifold.
Old May 8, 2007 | 07:21 PM
JimmyBoy's Avatar
JimmyBoy
ahhhhhhhh, that clears things up then.
Old May 8, 2007 | 07:37 PM
JimmyBoy's Avatar
JimmyBoy
Can a ERST charge carrier accept the FRST ACT sensor or are they totally different fitments ?
Thanks.
Old May 8, 2007 | 07:54 PM
Turbo-Beal's Avatar
Turbo-Beal
Im pretty shure they are the same as long as you have the aluminium adapter that come off with the sensor.
Old May 9, 2007 | 12:01 AM
SafeChav's Avatar
SafeChav
Should fit, but the adaptors are NLA from ford now......... (well apparently )
Old May 24, 2007 | 01:09 PM
JimmyBoy's Avatar
JimmyBoy
Is it the sensor in the middle of the efi inlet ?
Old May 24, 2007 | 02:29 PM
SafeChav's Avatar
SafeChav
No thats the CTS.
Its on the top half of the manifold, on the right port
Old May 30, 2007 | 08:21 PM
JimmyBoy's Avatar
JimmyBoy
Would you be able to point it out to me on this picture
Old May 30, 2007 | 11:31 PM
SafeChav's Avatar
SafeChav
big black thing, bottom left
Old May 30, 2007 | 11:34 PM
SafeChav's Avatar
SafeChav
Old May 30, 2007 | 11:45 PM
JimmyBoy's Avatar
JimmyBoy
CheeRS m8!
You say "big black thing, bottom left" but outline a white sensor top right lol, I presume it is the white sensor.
Old May 30, 2007 | 11:47 PM
SafeChav's Avatar
SafeChav
I was joking and saying it was the shoe
Old May 31, 2007 | 01:03 PM
JimmyBoy's Avatar
JimmyBoy
Old May 31, 2007 | 01:09 PM
SafeChav's Avatar
SafeChav
Old Jun 10, 2007 | 03:14 PM
JimmyBoy's Avatar
JimmyBoy
Ive got an xr2i inlet and it looks as though it has got the same sensor? would this be right ?
Old Jun 10, 2007 | 06:31 PM
MarkN's Avatar
MarkN
An XR2i has an air temperature sensor in the same place, but the sensor is NOT the same as a FRST one. FRST sensors are mounted in a adapter "boss" whereas the normal ones just screw straight into the manifold.
Old Jul 4, 2007 | 02:04 PM
JimmyBoy's Avatar
JimmyBoy
This guy is saying this one is from an RS, can anyone confirm it ?
Old Jul 4, 2007 | 09:07 PM
SafeChav's Avatar
SafeChav
That picture is small hard to make out the plug, but it looks not to be to me!
As MarkN will confirm for all you boys it has also come to our attention the FRST fuel rail loom is different aswell, so buying a N/A one will cause you grief!
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
