S2 Wont start when hot
Im a newbie here with a few problems, ive just bought an escort rst 1989 plate
The problem is the car will start and run fine when cold, although suntimes a little lumpy on tickover .
When its hot it just wont start, the starter turns, and i have a spark but it just wont fire.
If you leave the car for an hour it will start fine
Has anyone had this problem or has an idea what it mite be???
Desperate owner
Desperate owner
under the inlet manifold theres a plug going to the middle joining to a injector with a red thin pipe coming off it, take that off see if it starts when it hot as cold start valves on rst's are poo
I have same problem and try so much tnings and then in people in garage set my %co and clean metering head a little (man told me that he clean a little metering head, didint told me what exactly he doing) and now car starting fine.
