melted piston
Old May 7, 2007 | 11:46 PM
Barry R's Avatar
Barry R
Default melted piston
y does my escort turb keep melting the 4th piston
Old May 7, 2007 | 11:48 PM
SafeChav's Avatar
SafeChav
probably because you have something wrong?!
Old May 7, 2007 | 11:49 PM
Barry R's Avatar
Barry R
you think
Old May 7, 2007 | 11:50 PM
SafeChav's Avatar
SafeChav
its a bit of a stab in the dark but yea i'd say so
Old May 7, 2007 | 11:51 PM
Barry R's Avatar
Barry R
LOL
Old May 7, 2007 | 11:53 PM
Barry R's Avatar
Barry R
my new lump did 60 miles then started smokin its ass of just runnin it in
Old May 8, 2007 | 12:13 AM
scortmad's Avatar
scortmad
lean maybe
Old May 8, 2007 | 06:30 AM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
got tobe lean on number 4!
Old May 8, 2007 | 07:42 AM
More likely a lubrication problem, or air pocket and hot spot around no 4 cyclinder.
Old May 8, 2007 | 11:18 AM
SafeChav's Avatar
SafeChav
Ok being serious now.....whats the story with the car?
Are you trying to home DIY tune it for instance?
Old May 8, 2007 | 11:27 AM
Barry R's Avatar
Barry R
not really trying to do any thing it all started off with me racing a rx. i was going for it but the escort had a different idea & and went boom at about 120 mph since then it keeps melting pistons even though its a completely different engine its getting costly cant take it to a tuner cuz it doesnt last long enough HELP
Old May 8, 2007 | 04:44 PM
Alvyn's Avatar
Alvyn
have you had the injector that fuels number 4 checked to make sure it's working correctly?
Old May 8, 2007 | 08:47 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
swap injector 4 for 1 and see if it melts number 1 on your next engine sorry not funny
Old May 8, 2007 | 10:13 PM
LuiPoland's Avatar
LuiPoland
Default Re: melted piston
compare 4th injector with others
it can give less fuel and even when AFR (average) is good it can be too lean on 4th cylinder
Old May 8, 2007 | 10:22 PM
Barry R's Avatar
Barry R
i got a new set of injectors so i will change them, i have also been told it was [pinkin] wotever that means
Old May 8, 2007 | 10:33 PM
LuiPoland's Avatar
LuiPoland
pinkin - detonations
can be result of failed injector
Old May 9, 2007 | 12:12 AM
SafeChav's Avatar
SafeChav
There has to be something wrong with your fuel system then
injector/injector pipe/metering head, clearly under fuelling on cylinder number 4
Old May 9, 2007 | 07:46 AM
Phil79's Avatar
Phil79
But you have carried on without having it set up properly?
Old May 9, 2007 | 12:25 PM
Barry R's Avatar
Barry R
like i said i was trying to run it in it was a fresh lunp new internals the lot
Old May 9, 2007 | 12:27 PM
Barry R's Avatar
Barry R
i just had a quick look at the fourth injector the seal is fucked and the clamp that holds the injector in place is bent upwards so the injector moves in & out between 5-10mm could that be the prob?
Old May 9, 2007 | 01:01 PM
SafeChav's Avatar
SafeChav
yes
Ive got a set of injector seals and collets if you want to buy some, the collets alone are in excess of £3.50 +VAT from Ford
Clamps are NLA but you can buy stainless ones from auto specialists
Old May 9, 2007 | 01:07 PM
Barry R's Avatar
Barry R
Originally Posted by SafeChav
yes
no sorry mate i already got some they came in a mates head set so i robbed em hehehehe
Old May 9, 2007 | 01:16 PM
SafeChav's Avatar
SafeChav
fair enough, you'll have a job tracking down those clamps though........i've got a set i bought new and used but are still like new, think im going to hoard them for now on a "what if" basis
Old May 9, 2007 | 01:24 PM
Barry R's Avatar
Barry R
are they the same as 3i ones if so i got about 4 off them & a new set of injectors i bought a couple of years ago still got them i think
Old May 9, 2007 | 01:40 PM
SafeChav's Avatar
SafeChav
ooooo someones having a lucky day today then aren't they
Old May 9, 2007 | 01:43 PM
Barry R's Avatar
Barry R
so theyre the same then BONUS
Old May 10, 2007 | 12:43 PM
costina's Avatar
costina
Live long and prosper!!
check your voltage at the pump as old wiring can cause LOW volts at pump = less fuel=lean= melted piston=£££££'s or as above injector fault,have the fuel pressure checked by a pro before u large it again
Old May 10, 2007 | 01:06 PM
Barry R's Avatar
Barry R
i love that cortina
Old May 11, 2007 | 06:43 AM
dox's Avatar
dox
exactly what i was going to say worth getting the injectors
bench tested.
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
