saff clutches
Old May 7, 2007 | 05:48 PM
rickyboy's Avatar
rickyboy
Default saff clutches
hi guys,my 2wd saff clutch is really heavey its a standard car with 51k and had a new clutch fitted at 45k by previous owner,i was just wondering if all 2wd clutches are heavey or mine has had a cheap clutch fitted etc? thanks rich
Old May 7, 2007 | 07:14 PM
jon@work's Avatar
jon@work
it is more likely that your clutch cable has melted
Old May 7, 2007 | 07:16 PM
As jon@work says very common for cable to melt and go really heavy.
They are usually very light, too light if anything.
Old May 7, 2007 | 07:21 PM
rickyboy's Avatar
rickyboy
thinking about it it is abit nochy thanks for that guys ill try a cable and let u know the result rich
Old May 7, 2007 | 09:32 PM
BigErn's Avatar
BigErn
Mine feels like it has a small house on the other end of it! Its melted, noticed earlier today. Spare one in the boot on standby.
Old May 7, 2007 | 09:33 PM
dakar's Avatar
dakar
New clutch and cable in mine and its still too heavy
Old May 8, 2007 | 07:46 AM
Just make sure you put gearbox end in first then just lift pedal and the ratchet will release allowing you to push it back and slip cable in then let go few pumps of pedal all done!!
Old May 8, 2007 | 05:32 PM
rickyboy's Avatar
rickyboy
cheers guys
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
