Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
PUMA 1.7 juddering
Old May 7, 2007 | 10:44 AM
boofg's Avatar
boofg
Default PUMA 1.7 juddering
Hello I've just bought a PUMA 1.7 1998 and it seems to have a juddering problem. The juddering seems to be quite hard. It happens usually when I'm lifting of the accelerator pedal. I've heard the possible cause of the problem could be the hego sensor. I've disconnected the the hego sensor connector and it still juddered. I've disconnected the throttle position sensor connector and it stopped. Any thoughts? Thanks.
Old May 7, 2007 | 08:03 PM
phill295's Avatar
phill295
if you have disconnected the throttle position sensor connector and it stopped then i probaly the sensor
not saying for definate thou
Old May 7, 2007 | 09:26 PM
boofg's Avatar
boofg
Thanks for the info yeah I'll probably replace the tps.
Old May 8, 2007 | 11:56 AM
solidsteel1984's Avatar
solidsteel1984
I have the same problem on my 1.4 (98) but it only seems to happen at high speed (80-90 Mph say)... I took it to the garage for servicing last week and they didn't find anything wrong with it.
Does it happen at low speed too?
Old May 8, 2007 | 08:06 PM
boofg's Avatar
boofg
It seems to happen at low speed.
Old May 9, 2007 | 05:26 AM
Check the EXHAUST GAS PRESSURE DIFFERENTIAL SENSOR, (if it has one) will NOT show up as a fault on the ford software unless absolutely knackered though.
Had this on a few mondy's cause the same thing.
Old Aug 15, 2007 | 02:54 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
wheres the thingymabober your on about?
my missus puma does the same, and at any speed
i cleaned the iscv and it made no difference
and ive not looked since
Old Aug 15, 2007 | 06:02 PM
Wardy257's Avatar
Wardy257
It wont run without the TPS connected!!! Try disconecting the MAF first, if it improves you need to clean inside the MAF.
Old Aug 26, 2007 | 10:47 AM
Wickedest_Sin's Avatar
Wickedest_Sin
hi mate i have just had the same problem and after bying all sorts of things from coils to maf sensors it turned out to be the lamba sensor this is located at the back of the top of the engine it looks like a upside down spark plug with 4 wires coming out i bought one for £42 and my car is fine did u have problems with power too mine would stick at 2000 rpm then shoot like a turbo and the engine would judder like it was going to stall then rev itself
hope this helps
Sin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
Ben26
Sep 3, 2015 07:55 PM
