Crank position sensor??
Old May 7, 2007 | 10:40 AM
Robliddle's Avatar
Robliddle
Default Crank position sensor??
Been thinking of changing my Escort RS to EFI engine managment from the old mfi. wondered if any one had any tips on the bits i need and where to source them from. One thing im not sure of is the crank position sensor.My engine block is an early one so it does not have the hole at the bottom for the trigger sensor to slot in to like some of the later one did like the fiesta turbo.So am i right in thinking i can use one off a siera instead? Also i was told thet i can but a conversion plate so i can use fiesta inlet manifold on the mfi head?
Old May 7, 2007 | 12:19 PM
Turbo-Beal's Avatar
Turbo-Beal
Do a search in this forum there is plenty of info there
Old May 7, 2007 | 03:07 PM
jonesymk2's Avatar
jonesymk2
u can use the sierra 1.8cvh bottom pulley but it needs 2 b machined down,u also use the lower part of the sierra cambelt cover and the sierra alternator and bracket,u can buy an adaptor plate 2 use the efi inlet manifold on the mfi head,try looking on rsbible.co.uk thats quite good 4 info
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
