a few problems
Old May 6, 2007 | 12:30 PM
Cossie mk2's Avatar
Cossie mk2
Default a few problems
my xr3i dies if you put lights on and the rev counter needle bounces up and down when you put indicators on, dodgy wiring?
also, when the car is running, theres a high pitch knocking noise from inside the bonnet. i think its coming from the head but not 100% sure. does anybody know what this is?
cheers
Old May 6, 2007 | 02:16 PM
Dying and revs fluctuating with indicators check your CO first.
Noises are hard without hearing but knocks are by their nature nromally dull sounds like thuds, if it is more high pitched squeal look at timing belt tension first, especially if it changes with engine speed.
Old May 6, 2007 | 02:18 PM
Cossie mk2's Avatar
Cossie mk2
sounds high pitch 2 me but definately thuds. not timing belt as that is fine.
not meaning to sound dumb but CO?? i dont feel well so excuse me lol
Old May 7, 2007 | 01:14 PM
CO = fuel mixture, ie check it is not way too lean at idle as this will cause this, amazingly well.
You can adjust it yourself with allen key down hole to try, but I would just go see local freindly MOT place and get on gas machine, set to around 2-2.5%CO.
Old May 7, 2007 | 04:53 PM
Cossie mk2's Avatar
Cossie mk2
cheers. ill nick one of them from college but i promise 2 give it back
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
