does anyone how to set roof clock?
Old May 5, 2007 | 03:42 PM
flat out's Avatar
flat out
Default does anyone how to set roof clock?
alright boys and girls can anyone tell me how to set the the roof clock? iv tried all way and stll cant set it iv had a few clocks and the same problem is it something im doing? or do you have to take the battery of at 12.
thanks for looking
chris
Old May 5, 2007 | 03:48 PM
haz87's Avatar
haz87
ignition off. Turn the lights on. then adjust
Old May 5, 2007 | 03:51 PM
flat out's Avatar
flat out
cheers mate never tried that one
thanks alot chris
Old May 5, 2007 | 04:01 PM
haz87's Avatar
haz87
Took a while for me to work it out first time round as well
Old May 5, 2007 | 04:35 PM
addiction's Avatar
addiction
on mine i just push the buttons each side of the clock and it changes the time
Old May 5, 2007 | 05:45 PM
NIMRODS_RST's Avatar
NIMRODS_RST
MISSING MY RST!!
same here
Old May 5, 2007 | 05:53 PM
s1rststeve's Avatar
s1rststeve
same here
haz87's Avatar
haz87
On my old 3i it worked no matter what. But on my current car the lights have to be on
Old May 5, 2007 | 05:59 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
You have to ensure the ignition is ON otherwise it won't let you adjust anything. Have you tried that
Old May 5, 2007 | 11:46 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
ive tried adjusting mine with ignition on, do lights AND ignition need to be on?
Old May 5, 2007 | 11:50 PM
SafeChav's Avatar
SafeChav
wtf
turn the lights on - what a load of rubbish
Depends what clock you have there are 4 variants across the Mk3 & Mk4
Old May 6, 2007 | 05:55 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
All the clocks I've ever adjusted: S1/ S2/ non-Ford models, all you need is the ignition on, whether it be just on the key or the car running.
Nothing about the lights etc: they have nothing to do with it as far as I'm concerned (until proved otherwise ).
Old May 6, 2007 | 11:15 AM
SafeChav's Avatar
SafeChav
I've had experiences with all 4 different clocks and i agree you need the ignition on, and that only.
If he is adoment he has to have his lights on, hes either had his cars loom changed and they have got the ignition feed and illumination feed switched over, probably where the A pillar wiring has been cut, or the wiring plug on the clock has been soldered in wrong (the clocks illuminate with either an ignition feed or an illumination feed)
Old May 6, 2007 | 12:37 PM
haz87's Avatar
haz87
Im not lying lol! Im hardly gonna bullshit about a clock light
As i said on my old 3i it worked just with ignition but some reason on my current mk4 the lights have to be on. So obviously somethings been done with the wiring
Old May 6, 2007 | 01:14 PM
SafeChav's Avatar
SafeChav
As ive said above..........that will be the reason why
It SHOULD work off the ignition, not the lights though
Old May 6, 2007 | 03:42 PM
EssexMikeSi's Avatar
EssexMikeSi
i thought mine was fooked the other week as it wasnt adjusting then i realised u need the ignition on for it to let u change the time
Old May 6, 2007 | 11:03 PM
Grandad racer's Avatar
Grandad racer
dead simple, just turn on the ignition
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Neil Clark
Sep 8, 2015 07:06 PM
3doorcozmess
Sep 7, 2015 01:32 PM
