Dash Clocks
Old May 4, 2007 | 11:03 AM
mealor_1's Avatar
mealor_1
Default Dash Clocks
Hi
I have a R plate escort encore estate, and on the dash have the speedo, engine temp, fuel level and a picture of a car.
Does anybody know what this car in the dash should do? It has the handbrake light underneath, but that is the only thing on it which works??
Secondly, if i bought a dial which showed the engine revvs, would the required mechanics be behind this car so it could be replaced??
Thanks people
Old May 4, 2007 | 12:09 PM
SafeChav's Avatar
SafeChav
The car is just a hole filler being as its a lower spec model, just has the warning lights on it.
You would more than likely have to run a wire to the coil pack so the rev counter can get a signal.
Old May 4, 2007 | 01:17 PM
mealor_1's Avatar
mealor_1
thanks for the reply
i had heard that before from other people, but i thought id ask people in the know so to speak!!
would it be difficult to sort out a rev meter or should i leave alone??
Old May 4, 2007 | 02:44 PM
SafeChav's Avatar
SafeChav
Depends how confident you feel...........
Old May 4, 2007 | 04:31 PM
cossiegreg1's Avatar
cossiegreg1
i had a astra mk3 1.4.it had a clock where the rev counter was.
i got a hold of some astra clocks witha rev counter. when i took the old ones out i simply just plugged the new ones in using the same plug, no modifacations.
and everything worked. might be the same on your car mate
Old May 4, 2007 | 04:36 PM
SafeChav's Avatar
SafeChav
Vauxhalls aren't Fords.............
It won't have the rev counter wire - thats almost guaranteed, and i'd be surprised if the wiring configuration on the clocks is the same aswell cos they rarely are.
Old May 4, 2007 | 06:38 PM
Dave Parker's Avatar
Dave Parker
we put a rev counter speedo from rs2k in a mk 5b escort bonus which worked as the wire was there but it read double engine speed
Old May 4, 2007 | 07:56 PM
MarkN's Avatar
MarkN
My other half's 96' Fiesta Flight had a picture of the car. I bought a set of clocks and expected to have to run an extra wire to the coil but it already had it. The clocks plugged straight in and the revcounter just worked.
This is the first time I have ever had this with a Ford - I've always had to run an extra wire in older cars. It could be because 90% now come with a revcounter that they no longer bother having two different looms.
Point is - you might be lucky and they plug straight in
Old May 4, 2007 | 07:58 PM
MarkN's Avatar
MarkN
That's because you've fitted an ordinary revcounter to a car with a wasted spark coil pack (or is it the other way around )
Old May 5, 2007 | 09:23 AM
mealor_1's Avatar
mealor_1
Thanks for the replies.
I have just looked at what i would need to do to get to the clocks and it would involve removing the steering wheel and taking the whole of the dash out, and I don't fancy doing this if there is no cable behind.
So, I was wondering is there anyway of checking if I have the wire without the need to take apart the front of my car??
Old May 5, 2007 | 12:49 PM
SafeChav's Avatar
SafeChav
You shouldn't have to remove the dash, but steering wheel yes!
The only way to know for sure is to get the clocks out and see if the wire is there
Or find a car the same as urs down the scrappy and rip that apart........
Old May 5, 2007 | 02:09 PM
Dave Parker
you dont have to remove wheel just pull it forward and disconnect speedo cable it comes out to the side
Old May 5, 2007 | 07:19 PM
MarkN's Avatar
MarkN
That's right you can definately do it without removing the wheel.
Old May 5, 2007 | 07:41 PM
mealor_1's Avatar
mealor_1
I was reading the Haynes manual which is the reason I thought you had to remove the steering wheel. It was also on about messing around with the airbag, which isnt something i want to cock up!!
So just loosening the steering wheel will work then?
Old May 5, 2007 | 09:33 PM
MarkN's Avatar
MarkN
No you don't have to touch it at all. The clocks can slide out from behind it
Old May 5, 2007 | 11:38 PM
SafeChav's Avatar
SafeChav
Tis a bit of a tight squeeze without the wheel off though and you're almost guaranteed to scratch something.
Depends whether thats the kind of thing that bothers you i guess..........
Old May 6, 2007 | 09:24 AM
MarkN's Avatar
MarkN
If you've got the adjustable steering column it's a lot easier - pull it out as far as it will go.
If you haven't got a revcounter I would guess you don't have an adjustable column either tho...
Old May 6, 2007 | 12:16 PM
mealor_1's Avatar
mealor_1
I have a fixed steering wheel, it doesnt have any adjustments on it
Mark_
14
Jan 16, 2016 05:27 PM
Fordmad!
Sep 29, 2015 07:03 PM
Mr S1
20
Sep 27, 2015 04:06 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
