passenger side driveshaft
May 3, 2007 | 02:20 PM
if i change the passenger side driveshaft will i need to put new gearbox oil? or is that the drivers side?
May 3, 2007 | 02:54 PM
Both the same. But if you pull the old out and put the new in within 10s you won't lose any significant quantity.
May 3, 2007 | 04:22 PM
Jack the passenger side up quite high and leave the drivers side on the ground should eliminate most oil loss.
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
