5th injection...
Old May 2, 2007 | 06:26 PM
GuGu's Avatar
GuGu
Default 5th injection...
How can I do it? Is it necessary on a RST boosted 13 psi? What are the advantages of it?
Thanks...
Old May 2, 2007 | 07:10 PM
timturbo's Avatar
timturbo
i couldnt tell you how to do it but what it does is dump fuel into the mfi plenun which increases your fuel rate as you cant change injectors running mfi
Old May 2, 2007 | 07:26 PM
gaz s1's Avatar
gaz s1
You dont need it on 13 psi mate
Old May 5, 2007 | 08:30 PM
steven botes's Avatar
steven botes
13 psi will not need a fifth injector
in SA before local tuners reversed engineered the Ausie Microtech and built the Domingos(now Gotech) standalone system , we used a hop switch(adjustable pressure switch) wired to a microfueler with an injector plumbed into the intake
at a set pressure , the hop switch closes , activates the microfueler which pulses the injector. The microfuelers pulse duration is adjustable
arcane way of dumping fuel into your motor though
Old May 5, 2007 | 08:52 PM
T28 RST's Avatar
T28 RST
Ok then
Default Re: 5th injection...
Thanks...
What other mods do you have, if the engine has all the correct bits it could max out the MFi at 13psi
Old May 6, 2007 | 09:09 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
5th Injector isn't a bad idea. Due to the primative adjustment of the MFi system, it will allow you to run sensible off/low boost fuelling and provide the increased fuel required for boost.
IMO, MFi can do 13psi, but the above applies.
Chas
Oct 5, 2015 07:13 PM
CLIVE
Oct 2, 2015 12:58 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
billybob
62
Aug 25, 2015 07:21 AM
Aug 8, 2015 07:12 AM
