s1 gear linkage
Old May 1, 2007 | 10:00 PM
syko2005's Avatar
syko2005
burning oil
Default s1 gear linkage
hi all can anybody tell me where i can get a new gear linkage for my s1 turbo its a bit on the sloppy side and 3rd is a bitch sometimes so wanted to do somethin about it
Old May 1, 2007 | 11:22 PM
SafeChav's Avatar
SafeChav
Get the bits and service it, its only worn parts making it sloppy.
Doubt very much if you'll find a new linkage easily
Old May 2, 2007 | 11:56 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Can you get a service kit for it? what about the actual selector on the gearbox the linkage connects too? think mines a bit worn.
Old May 2, 2007 | 01:03 PM
sm's Avatar
sm
get a b&m quickshift it improves the gearchange no end u will need to use ur old selctor and stabilser rod though as they dont come with them and are no longer avalible from ford the b&m is about £215
Old May 2, 2007 | 02:49 PM
SafeChav's Avatar
SafeChav
The selector in the box will never wear to that extent, its always the linkage trust me.
Old May 2, 2007 | 03:10 PM
JesseT's Avatar
JesseT
From experience I don't trush you. The stick, casing bottom, casing top cover, etc. are usually extreamly worn and beyond repair. As a bonus, some parts cost so much that one can buy two new complete Puma shifters for the price of the replacement parts.
Old May 2, 2007 | 08:22 PM
NUTS RuS's Avatar
NUTS RuS
Whack the U/J with a hammer to tighten it down a bit.
If its worn shim it with washers then whack it lol
Old May 2, 2007 | 09:50 PM
jimmylaud's Avatar
jimmylaud
i just got a new selector with the u/j on it from ford in kirkcaldy cant mind how much it was that much
Old May 2, 2007 | 10:12 PM
SafeChav's Avatar
SafeChav
nice
Old May 2, 2007 | 10:18 PM
jimmylaud's Avatar
jimmylaud
meant to say it was for a s2 tho dont know if it makes much odds
Old May 2, 2007 | 10:23 PM
SafeChav's Avatar
SafeChav
All the same
Old May 2, 2007 | 11:25 PM
NUTS RuS's Avatar
NUTS RuS
Internals are different
S1 has the 'gate' in the bottom of the plastic bit
Old May 2, 2007 | 11:26 PM
SafeChav's Avatar
SafeChav
yea i just meant the same on all Mk4's and the same on all Mk3's
Old May 2, 2007 | 11:39 PM
NUTS RuS's Avatar
NUTS RuS
Same - but different
Old May 3, 2007 | 12:20 AM
SafeChav's Avatar
SafeChav
Old May 8, 2007 | 11:51 AM
series1rscars's Avatar
series1rscars
i bought the gear stick & bushes from ford 18 months ago. cost me about £50 for the stick & pennies for the bushes. Could be worth a try
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
