rs turbo ecu
Old May 1, 2007 | 04:24 PM
mulla's Avatar
mulla
Default rs turbo ecu
can anyone tell me how to check if your ecu is working properly
Old May 1, 2007 | 05:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
You need to have it put on a fault code reader.
Old May 1, 2007 | 06:24 PM
swerv's Avatar
swerv
do rs turbo ecus have fault codes damn never knew that
i thought if it runs it works
Old May 1, 2007 | 07:50 PM
fast_ford_uk's Avatar
fast_ford_uk
you can plug a reader into it if you have the correct software, the car can still run even tho the ecu is fucked, depends which part is fucked, but it will do all sorts of damage
Old May 1, 2007 | 09:12 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
I think the only thing that is likely to fail is the integrated MAP sensor. Had that on one of my RSTs once.
Old May 1, 2007 | 11:32 PM
SafeChav's Avatar
SafeChav
RST's will run with no fuel ECU....admittedly like a pile of shit but they will do it, they operate like K-Jetronic when something on the fuel management fails.
PeterRST thats the ignition ECU not the fuel one
Old May 2, 2007 | 03:24 PM
JesseT's Avatar
JesseT
K-jetronic is a bit more complex than KE with no ecu.
Mulla,
Which ecu are you refering to? Nobody said fuel ecu but Safechav.
Old May 2, 2007 | 04:40 PM
mulla's Avatar
mulla
its the one behind the heater blower,when i start her up she starts for one second then stops,keeps doing that when it starts up black smoke comes out if i turn her off and try again it wont start keeps doing that,before this happend it sounded like it was fireing on three cylinders,it gradually got worse i changed the plugs as they were black,changed leads but still same problem just does not fire up,so i think its the ecu or metering unit any help please.
Old May 2, 2007 | 04:46 PM
SafeChav's Avatar
SafeChav
Ahhhh sorry im sure i read fuel ECU
And jesse you are right i know K is a bit more complicated then KE without an ECU, hence why KE wont start well from cold when the management fails
Old May 2, 2007 | 05:04 PM
mulla's Avatar
mulla
were is the fuel ecu
Old May 2, 2007 | 06:12 PM
SafeChav's Avatar
SafeChav
Next to the silver ignition ECU, its black.
Old May 2, 2007 | 06:26 PM
mulla's Avatar
mulla
just stripped the metering unit down just in case looked alright .i put it back on the car but did not put the injection pipes back on fuel came out of the coldstart hole so fastened that back on but on the injectors fuel only came out of one what do you think.
Old May 2, 2007 | 07:00 PM
SafeChav's Avatar
SafeChav
Sounds like its got an internal fault
Old May 2, 2007 | 07:08 PM
mulla's Avatar
mulla
going to have to replace it to try it out anyone got one
Old May 2, 2007 | 09:59 PM
SafeChav's Avatar
SafeChav
Its got to be fauly if one sprays fuel the other 3 should spray equally, its continuous injection
Old May 3, 2007 | 08:02 AM
mulla's Avatar
mulla
i hope so got one on its way now
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
Marcus L
Aug 29, 2015 02:18 PM
IAN RS2k
Aug 18, 2015 07:51 PM
