dump valve woes
Old May 1, 2007 | 03:54 PM
cossie_pol's Avatar
cossie_pol
Default dump valve woes
my friend has just fitted a dump valve to his rst (by cutting the hose an fitting in a 'T' piece) an it stalls an struggles to idle,
is it gonna be a case of a dodgy seal on the pipe he's cut?
cheers
dave
Old May 1, 2007 | 04:14 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
is it a twin piston dump valve?
is it a new dump valve?
its more likely the d/v leaking air or being a single piston or diaphram type which isnt suitable to use on an ERST.
Old May 1, 2007 | 04:15 PM
Moonie's Avatar
Moonie
My advice (and proably most of the people that will reply to this) is to remove it as they cause more problems than they are worth.
What sort of valve has he fitted? The wrong one will cause an air leak.
Old May 1, 2007 | 04:24 PM
Oranoco's Avatar
Oranoco
Seconded. They are fucking shit on RST's and do bugger all but balls up the running and make you sound like a bus
Old May 1, 2007 | 11:23 PM
SafeChav's Avatar
SafeChav
As has been said its probably not a Twin piston type.
Up to you if you want to persuade him to remove it or not but a twin piston one is what he wants if he insists on having one
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
