2.8 V6 COLOGNE MISFIRE!!
Old Apr 30, 2007 | 02:50 PM
cossie04's Avatar
cossie04
Default 2.8 V6 COLOGNE MISFIRE!!
I have an XR4i and it has a misfire. I`ve started checking for a spark at each lead and that is fine. This has caused me to believe it is head related.
I have taken off the H.T leads off one at a time to try and find which valve it is. Whenever i take the a lead off on the passenger side, it mis fires a bit more which i think should happen, but if i take a lead of the drivers side, the misfire dosn`t get any worse...
Has anyone ever expirenced this on the cologne before?
Do i need a new engine?, Head? etc ?????
Someone please help me........!!
Cheers, Ed.
Old Apr 30, 2007 | 07:13 PM
ukfalcon's Avatar
ukfalcon
If it does not get any worse on any of the cylinders on one bank it has got to be something comman to all cylinders so unlikely to be valve/head fault. First thing to check would be inlet manifold gasket or an air leak on a vac hose on that side of the manifold.
Old May 1, 2007 | 01:19 PM
cossie04's Avatar
cossie04
I`ve just checked them two, to no avail.
I bought the car with a misfire, and he said that he had done a decoke on it including new headgasket. Not to sure what he means by that.
Any ideas? Really f**kin me off now!!!
Old May 1, 2007 | 03:31 PM
I would be tempted to start with the basics ie timimg, ignition and cam and also do a dizzy swing to see if it improves first, check plug gaps etc and colour to see if rich, then try adjustiong after timimg swing the idle mix.
I have found from my short experience with these that they need a huge amount of ignition advance.
Old May 1, 2007 | 10:18 PM
gup's Avatar
gup
have you checked the tappets to c if they are adjusted correctly
my friends one did this and he was told headgasket had went
i adjusted the tappets for him and its still going strong today
Old May 2, 2007 | 07:29 AM
cossie04's Avatar
cossie04
Cheers for the help guys. I `m gonna run through that list when i get back from work, and hopefully it might work. I`ll keep ya posted....
Old May 6, 2007 | 07:58 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
worked on loads of 2.8 capris myself.inlet manifold gasket always goes!
Old May 7, 2007 | 01:23 PM
2001ode's Avatar
2001ode
Hi,
Inlet manifold gasket defective, IMO.
It is only 2 problems on this engine : inlet manifold gasket and oil pomp shaft.
Regards.
Claude
Old May 7, 2007 | 09:35 PM
dakar's Avatar
dakar
Rs graham is right inlet manifold gasket would be favourite mate
Old May 8, 2007 | 11:24 AM
cossie04's Avatar
cossie04
Cheers guys, gonna change even if it does seem fine.
With any luck I might have a 24v v6 cossie lump in there before the end of the month!!...
j.hammond1
30
Oct 31, 2021 05:28 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
