Starter motor
Hi guys, whats the difference between the starter motor on the RST and a normal 1600 CVH starter? i have just fitted a new TT stage 2 turbo on my RS and the oil return now fouls the solenoid on mine
Help
Help
RST starters are FOOKIN massive
That solenoid does look in a bit of a dodgy position, but people in the know run smaller starters anyway, RSt's are low compression so its easier to crank over the a N/A engine
Guess its gonna be a trip down the scrappys for a starter motor then
Am gutted cos i trimmed the oil return pipe down for the old turbo, and now it dont fit
Its the L shaped return pipe i got from Roose motorsport, i assume that because my new turbo has a larger compressor housing the oil return is situated further out
