setting the fuel pressure on a frst please help
i have a escort cosworth fuel pump on my frst with 'beige' injectors and 195bhp power chip when the car was running with it all on it was not Idling
Properly very lumpy on tick over and trying to cut out i was told it was because i had a fse power boost valve or fse fuel pressure regulator on the car and told to get a weber 1 the standard 1 for the frst im just Wondering when i fit this will i sort the problem strate away or will the weber 1 have to be adjusted and if so how is it done.
thanks alex
thanks alex
It may need adjusting, try and get one which still has its original tamper seal on it.
Ive got one somewhere i can sell you, not sure if it has its tamper seal or not though
This is not a for sale post btw
Originally Posted by SafeChav
It expired a week or so ago.
Dragging it out a bit before i spend another Ł20
Did'nt think it had been a year already
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
