finis code request
Old Apr 30, 2007 | 08:18 AM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
Default finis code request
Hi There
wondering if anyone knows the finis codes for the following:
* Inlet manifold gasket - not the one that goes between head/injectors, but the one that goes between the injectors and the body of the manifold (possibly the same gasket??)
* an injector
* The adjustable screw that goes under the throttle body (idel speed majbe??)
* the oval shaped gasket for a bit on the head, not sure what this is, its a wee metal oval thing that bolts on woth 2 bolts and has a ford badge on it
* again dont know the name of this, but it screws into the front of the head and has a wire with an "0" terminal on it
sorry for the lack of technical names! If I had a decent pic of the engine bay id circle what I was meaning... cheers
Jamie
Old Apr 30, 2007 | 09:51 AM
antony215's Avatar
antony215
Escort Rs Turbo
Default Re: finis code request
You can get all that from www.burtonpower.com
apart for this dont think they do them
Old Apr 30, 2007 | 10:14 AM
RodgeRS_Turbo
cheers mate ill have a look
Old Apr 30, 2007 | 12:02 PM
RodgeRS_Turbo
where about on the website mate?
is it just the part number under each individual item? Or is that the burton power part number? cheers
Old Apr 30, 2007 | 12:07 PM
antony215's Avatar
antony215
Escort Rs Turbo
Under Engine Components then click on gaskets & seals then cvh and it will come up with all the gasket sets they do for the cvh
Old Apr 30, 2007 | 12:30 PM
RodgeRS_Turbo
cheers for that. you dont happen to know what this thing is do you?
Do you know what the oval thing actually is?
I know its a pretty piss description but I dont want to go into Ford sounding like a total idiot!
cheers again
Old Apr 30, 2007 | 12:31 PM
SafeChav's Avatar
SafeChav
Its a blanking plate for the fuel pump that the carbeurettor models have.
You could easily make a gasket for that with some gasket paper....
Old Apr 30, 2007 | 12:54 PM
antony215's Avatar
antony215
Escort Rs Turbo
As above it's just a blanking plate. If i were you id get a complet gasket set then you have all the gaskets you need.
Hi There
That will be the water temp sensor
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
focus2351
Sep 9, 2015 09:33 PM
