Can an unhealthy spark plug lose your car power...
WITHOUT causing a misfire??
ie... the car feels a bit flat like the timing is pulling back?
Lee
Lee
Yes.
The weaker spark only ignites a small portion of the total spark availablity
surface area so it takes extra time for the already burning mixture to
ignite the rest. In effect, this is like retarding the ignition very slightly.
PassionFords Creator
Originally Posted by Electronic
Yes.
Incidentally, this is how swopping to wasted spark can improve your power output for the same boost.
stu like i said on the last thread,,, i understand the result but aint got a clue what hc ppm means,,,,, im guessing its hydrocarbons per mixture of what ever amount just like the mot machine reads
but aslong as i know the end result ill get by ok
Originally Posted by markk
no but a a large crack in your block and water all over my drive will certainly not be doing you any favours
Ha bloody ha
Zoggon
Aug 10, 2015 10:39 AM
im sure your right though
